brand new 2.8" TFT Touch Shield not working
Re: brand new 2.8" TFT Touch Shield not working
by adafruit_support_carter on Fri Aug 23, 2019 12:22 pm
OK, no worries. I think that is what is happening. For the MEGA, you'll likely need to cut/solder those pads.
We are looking into our documentation on this. It seems inconsistent and out of sync with the current product rev in some places.
by MakerMelissa on Fri Aug 23, 2019 12:42 pm
Thanks for pointing this out. Documentation has been updated.
MakerMelissa
by MakerMelissa on Fri Aug 23, 2019 8:19 pm
The board repo was out of date, but now contains the latest schematics as well.
MakerMelissa
by davidsi on Mon Aug 26, 2019 10:40 pm
here you go
2019-08-26 19.33.32.jpg (91.01 KiB) Viewed 94 times
davidsi
by MakerMelissa on Mon Aug 26, 2019 10:48 pm
Thanks for providing the photo. For the Mega, you'll need to cut the traces on the pads for pins 11-13 in the lower left and bridge the ICSP ones. You can follow the preparing the board section of this page: https://learn.adafruit.com/adafruit-2-8 ... quickstart which has photos and is the same steps for the Mega.
MakerMelissa
by davidsi on Tue Aug 27, 2019 12:31 am
THANK YOU
davidsi
by hayiwada on Tue Oct 29, 2019 7:52 am
MakerMelissa wrote:Thanks for providing the photo. For the Mega, you'll need to cut the traces on the pads for pins 11-13 in the lower left and bridge the ICSP ones. You can follow the preparing the board section of this page: https://learn.adafruit.com/adafruit-2-8 ... quickstart which has photos and is the same steps for the Mega.
Hi, my 2.8" TFT Touch screen for arduino, resistive touch screen just arrived, when i try to put code on arduino MEGA it's the same giving me the white screen. So may I know, if there is other option without soldering to fix it? Previously, my last TFT works fine without soldering it and at that time I used UNO.
hayiwada
by MakerMelissa on Tue Oct 29, 2019 11:31 am
Hi hayiwada,
It depends. If it is a shield, you may be able to get away with using "bit banging" to do software. This has the effect of being slow, but you can use pins that aren't dedicated to SPI. If you have a breakout, you can tie the corresponding IM pins to the 3vo pin to temporarily change it. You should definitely take a look around on learn.adafruit.com for your corresponding display. I've been doing lots of guide updates and hopefully that will answer any other question you have.
Thanks,
Melissa
MakerMelissa
