RGB Push Button Code
by dmnagy6192 on Thu Aug 22, 2019 11:46 pm
I recently purchased a Rugged Metal RGB Momentary Pushbutton (https://www.adafruit.com/product/3350) for use in my current project. When pressed, it changes the pattern being displayed on a strip of NeoPixels.
My code for the NeoPixels and function of the button is working fine but I am having trouble with the color displayed on the RGB button itself. I would like the RGB button to cycle through a handful of colors (as seen in the "New Product" video it is featured in on YouTube); however it is only displaying White.
Prior to adding this button to my project, I tested it using the RGB LED example code (https://learn.adafruit.com/adafruit-ard ... ino-sketch) and the given colors cycled through as expected.
How would I combine the example code (above) into my current project? I tried to simply cut and paste the example code into my project's code but the RGB only displayed white.
I am very new to programming so I apologize if any of this was confusing or if my code is a bit messy.
I am using an Arduino Uno R3 with the following attached:
5v > Common Cathode
Red Anode > PIN11
Green Anode > PIN10
Blue Anode > PIN9
Button > PIN 2 & Ground
NeoPixels > PIN6
#include <EEPROM.h>
#ifdef __AVR__
  #include <avr/power.h>
  #endif
#define NUM_LEDS 59
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
#define BUTTON 2 //button must be on pin 2 or 3 when used as interrupt!
byte selectedEffect=0;
//definition of RGB button
int redPin = 11;
int greenPin = 10;
int bluePin = 9;
//uncomment this line if using a Common Anode LED
//#define COMMON_ANODE
void setup()
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  digitalWrite (BUTTON, HIGH);  // internal pull-up resistor
  attachInterrupt (digitalPinToInterrupt (BUTTON), changeEffect, CHANGE); // pressed
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
// *** REPLACE FROM HERE ***
void loop(){
  EEPROM.get(0,selectedEffect);
  if(selectedEffect>18) {
    selectedEffect=0;
    EEPROM.put(0,0);
 //begin button commands
  switch(selectedEffect) {
    case 0  : {
                // RGBLoop - no parameters
                RGBLoop();
                break;
    case 1  : {
                // FadeInOut - Color (red, green. blue)
                FadeInOut(0xff, 0x00, 0x00); // red
                FadeInOut(0xff, 0xff, 0xff); // white
                FadeInOut(0x00, 0x00, 0xff); // blue
                break;
    case 2  : {
                // Strobe - Color (red, green, blue), number of flashes, flash speed, end pause
                Strobe(0xff, 0xff, 0xff, 10, 50, 1000);
                break;
    case 3  : {
                // HalloweenEyes - Color (red, green, blue), Size of eye, space between eyes, fade (true/false), steps, fade delay, end pause
                HalloweenEyes(0xff, 0x00, 0x00,
                              1, 4,
                              true, random(5,50), random(50,150),
                              random(1000, 10000));
                              1, 4,
                break;
    case 4  : {
                // CylonBounce - Color (red, green, blue), eye size, speed delay, end pause
                CylonBounce(0xff, 0x00, 0x00, 4, 10, 50);
                break;
    case 5  : {
                // NewKITT - Color (red, green, blue), eye size, speed delay, end pause
                NewKITT(0xff, 0x00, 0x00, 8, 10, 50);
                break;
    case 6  : {
                // Twinkle - Color (red, green, blue), count, speed delay, only one twinkle (true/false)
                Twinkle(0xff, 0x00, 0x00, 10, 100, false);
                break;
    case 7  : {
                // TwinkleRandom - twinkle count, speed delay, only one (true/false)
                TwinkleRandom(20, 100, false);
                break;
    case 8  : {
                // Sparkle - Color (red, green, blue), speed delay
                Sparkle(0xff, 0xff, 0xff, 0);
                break;
    case 9  : {
                // SnowSparkle - Color (red, green, blue), sparkle delay, speed delay
                SnowSparkle(0x10, 0x10, 0x10, 20, random(100,1000));
                break;
    case 10 : {
                // Running Lights - Color (red, green, blue), wave dealy
                RunningLights(0xff,0x00,0x00, 50);  // red
                RunningLights(0xff,0xff,0xff, 50);  // white
                RunningLights(0x00,0x00,0xff, 50);  // blue
                break;
    case 11 : {
                // colorWipe - Color (red, green, blue), speed delay
                colorWipe(0x00,0xff,0x00, 50);
                colorWipe(0x00,0x00,0x00, 50);
                break;
    case 12 : {
                // rainbowCycle - speed delay
                rainbowCycle(20);
                break;
    case 13 : {
                // theatherChase - Color (red, green, blue), speed delay
                theaterChase(0xff,0,0,50);
                break;
    case 14 : {
                // theaterChaseRainbow - Speed delay
                theaterChaseRainbow(50);
                break;
    case 15 : {
                // Fire - Cooling rate, Sparking rate, speed delay
                Fire(55,120,15);
                break;
              // simple bouncingBalls not included, since BouncingColoredBalls can perform this as well as shown below
              // BouncingColoredBalls - Number of balls, color (red, green, blue) array, continuous
              // CAUTION: If set to continuous then this effect will never stop!!!
    case 16 : {
                // mimic BouncingBalls
                byte onecolor[1][3] = { {0xff, 0x00, 0x00} };
                BouncingColoredBalls(1, onecolor, false);
                break;
    case 17 : {
                // multiple colored balls
                byte colors[3][3] = { {0xff, 0x00, 0x00},
                                      {0xff, 0xff, 0xff},
                                      {0x00, 0x00, 0xff} };
                BouncingColoredBalls(3, colors, false);
                break;
    case 18 : {
                // meteorRain - Color (red, green, blue), meteor size, trail decay, random trail decay (true/false), speed delay
                meteorRain(0xff,0xff,0xff,10, 64, true, 30);
                break;
void changeEffect() {
  if (digitalRead (BUTTON) == HIGH) {
    selectedEffect++;
    EEPROM.put(0, selectedEffect);
    asm volatile ("  jmp 0");
// ** LEDEffect Functions **
void RGBLoop(){
  for(int j = 0; j < 3; j++ ) {
    // Fade IN
    for(int k = 0; k < 256; k++) {
      switch(j) {
        case 0: setAll(k,0,0); break;
        case 1: setAll(0,k,0); break;
        case 2: setAll(0,0,k); break;
      showStrip();
      delay(3);
    // Fade OUT
    for(int k = 255; k >= 0; k--) {
      switch(j) {
      showStrip();
      delay(3);
void FadeInOut(byte red, byte green, byte blue){
  float r, g, b;
  for(int k = 0; k < 256; k=k+1) {
    r = (k/256.0)*red;
    g = (k/256.0)*green;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
  for(int k = 255; k >= 0; k=k-2) {
    r = (k/256.0)*red;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
void Strobe(byte red, byte green, byte blue, int StrobeCount, int FlashDelay, int EndPause){
  for(int j = 0; j < StrobeCount; j++) {
    setAll(red,green,blue);
    showStrip();
    delay(FlashDelay);
    setAll(0,0,0);
    showStrip();
    delay(FlashDelay);
 delay(EndPause);
void HalloweenEyes(byte red, byte green, byte blue,
                   int EyeWidth, int EyeSpace,
                   boolean Fade, int Steps, int FadeDelay,
                   int EndPause){
  randomSeed(analogRead(0));
  int i;
  int StartPoint  = random( 0, NUM_LEDS - (2*EyeWidth) - EyeSpace );
  int Start2ndEye = StartPoint + EyeWidth + EyeSpace;
  for(i = 0; i < EyeWidth; i++) {
    setPixel(StartPoint + i, red, green, blue);
    setPixel(Start2ndEye + i, red, green, blue);
  showStrip();
  if(Fade==true) {
    float r, g, b;
    for(int j = Steps; j >= 0; j--) {
      r = j*(red/Steps);
      g = j*(green/Steps);
      b = j*(blue/Steps);
        setPixel(StartPoint + i, r, g, b);
        setPixel(Start2ndEye + i, r, g, b);
      showStrip();
      delay(FadeDelay);
  setAll(0,0,0); // Set all black
  delay(EndPause);
void CylonBounce(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
    setAll(0,0,0);
    setPixel(i, red/10, green/10, blue/10);
    for(int j = 1; j <= EyeSize; j++) {
      setPixel(i+j, red, green, blue);
    setPixel(i+EyeSize+1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
  for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// used by NewKITT
void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i =((NUM_LEDS-EyeSize)/2); i>=0; i--) {
    setAll(0,0,0);
    setPixel(NUM_LEDS-i, red/10, green/10, blue/10);
      setPixel(NUM_LEDS-i-j, red, green, blue);
    setPixel(NUM_LEDS-i-EyeSize-1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i = 0; i<=((NUM_LEDS-EyeSize)/2); i++) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void Twinkle(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
  for (int i=0; i<Count; i++) {
     setPixel(random(NUM_LEDS),red,green,blue);
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void TwinkleRandom(int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
     setPixel(random(NUM_LEDS),random(0,255),random(0,255),random(0,255));
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void Sparkle(byte red, byte green, byte blue, int SpeedDelay) {
  int Pixel = random(NUM_LEDS);
  setPixel(Pixel,red,green,blue);
  showStrip();
  delay(SpeedDelay);
  setPixel(Pixel,0,0,0);
void SnowSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
  setPixel(Pixel,0xff,0xff,0xff);
  showStrip();
  delay(SparkleDelay);
  showStrip();
  delay(SpeedDelay);
void RunningLights(byte red, byte green, byte blue, int WaveDelay) {
  int Position=0;
  for(int i=0; i<NUM_LEDS*2; i++)
      Position++; // = 0; //Position + Rate;
      for(int i=0; i<NUM_LEDS; i++) {
        // sine wave, 3 offset waves make a rainbow!
        //float level = sin(i+Position) * 127 + 128;
        //setPixel(i,level,0,0);
        setPixel(i,((sin(i+Position) * 127 + 128)/255)*red,
                   ((sin(i+Position) * 127 + 128)/255)*green,
                   ((sin(i+Position) * 127 + 128)/255)*blue);
      showStrip();
      delay(WaveDelay);
void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
  for(uint16_t i=0; i<NUM_LEDS; i++) {
      setPixel(i, red, green, blue);
      showStrip();
      delay(SpeedDelay);
void rainbowCycle(int SpeedDelay) {
  byte *c;
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< NUM_LEDS; i++) {
      c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
      setPixel(i, *c, *(c+1), *(c+2));
    showStrip();
    delay(SpeedDelay);
// used by rainbowCycle and theaterChaseRainbow
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
  } else {
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
void theaterChase(byte red, byte green, byte blue, int SpeedDelay) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < NUM_LEDS; i=i+3) {
        setPixel(i+q, red, green, blue);    //turn every third pixel on
      showStrip();
      delay(SpeedDelay);
        setPixel(i+q, 0,0,0);        //turn every third pixel off
void theaterChaseRainbow(int SpeedDelay) {
  byte *c;
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
          c = Wheel( (i+j) % 255);
          setPixel(i+q, *c, *(c+1), *(c+2));    //turn every third pixel on
        showStrip();
        delay(SpeedDelay);
void Fire(int Cooling, int Sparking, int SpeedDelay) {
  static byte heat[NUM_LEDS];
  int cooldown;
  // Step 1.  Cool down every cell a little
  for( int i = 0; i < NUM_LEDS; i++) {
    cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
    if(cooldown>heat[i]) {
      heat[i]=0;
    } else {
      heat[i]=heat[i]-cooldown;
  // Step 2.  Heat from each cell drifts 'up' and diffuses a little
  for( int k= NUM_LEDS - 1; k >= 2; k--) {
    heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
  // Step 3.  Randomly ignite new 'sparks' near the bottom
  if( random(255) < Sparking ) {
    int y = random(7);
    heat[y] = heat[y] + random(160,255);
    //heat[y] = random(160,255);
  // Step 4.  Convert heat to LED colors
  for( int j = 0; j < NUM_LEDS; j++) {
    setPixelHeatColor(j, heat[j] );
  showStrip();
  delay(SpeedDelay);
void setPixelHeatColor (int Pixel, byte temperature) {
  // Scale 'heat' down from 0-255 to 0-191
  byte t192 = round((temperature/255.0)*191);
  // calculate ramp up from
  byte heatramp = t192 & 0x3F; // 0..63
  heatramp <<= 2; // scale up to 0..252
  // figure out which third of the spectrum we're in:
  if( t192 > 0x80) {                     // hottest
    setPixel(Pixel, 255, 255, heatramp);
  } else if( t192 > 0x40 ) {             // middle
    setPixel(Pixel, 255, heatramp, 0);
  } else {                               // coolest
    setPixel(Pixel, heatramp, 0, 0);
void BouncingColoredBalls(int BallCount, byte colors[][3], boolean continuous) {
  float Gravity = -9.81;
  int StartHeight = 1;
  float Height[BallCount];
  float ImpactVelocityStart = sqrt( -2 * Gravity * StartHeight );
  float ImpactVelocity[BallCount];
  float TimeSinceLastBounce[BallCount];
  int   Position[BallCount];
  long  ClockTimeSinceLastBounce[BallCount];
  float Dampening[BallCount];
  boolean ballBouncing[BallCount];
  boolean ballsStillBouncing = true;
  for (int i = 0 ; i < BallCount ; i++) {
    ClockTimeSinceLastBounce[i] = millis();
    Height[i] = StartHeight;
    Position[i] = 0;
    ImpactVelocity[i] = ImpactVelocityStart;
    TimeSinceLastBounce[i] = 0;
    Dampening[i] = 0.90 - float(i)/pow(BallCount,2);
    ballBouncing[i]=true;
  while (ballsStillBouncing) {
      TimeSinceLastBounce[i] =  millis() - ClockTimeSinceLastBounce[i];
      Height[i] = 0.5 * Gravity * pow( TimeSinceLastBounce[i]/1000 , 2.0 ) + ImpactVelocity[i] * TimeSinceLastBounce[i]/1000;
      if ( Height[i] < 0 ) {
        Height[i] = 0;
        ImpactVelocity[i] = Dampening[i] * ImpactVelocity[i];
        if ( ImpactVelocity[i] < 0.01 ) {
          if (continuous) {
          } else {
            ballBouncing[i]=false;
      Position[i] = round( Height[i] * (NUM_LEDS - 1) / StartHeight);
    ballsStillBouncing = false; // assume no balls bouncing
      setPixel(Position[i],colors[i][0],colors[i][1],colors[i][2]);
      if ( ballBouncing[i] ) {
    showStrip();
    setAll(0,0,0);
void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  setAll(0,0,0);
  for(int i = 0; i < NUM_LEDS+NUM_LEDS; i++) {
    // fade brightness all LEDs one step
    for(int j=0; j<NUM_LEDS; j++) {
      if( (!meteorRandomDecay) || (random(10)>5) ) {
        fadeToBlack(j, meteorTrailDecay );
    // draw meteor
    for(int j = 0; j < meteorSize; j++) {
      if( ( i-j <NUM_LEDS) && (i-j>=0) ) {
        setPixel(i-j, red, green, blue);
    showStrip();
    delay(SpeedDelay);
// used by meteorrain
void fadeToBlack(int ledNo, byte fadeValue) {
 #ifdef ADAFRUIT_NEOPIXEL_H
    // NeoPixel
    uint32_t oldColor;
    uint8_t r, g, b;
    int value;
    oldColor = strip.getPixelColor(ledNo);
    r = (oldColor & 0x00ff0000UL) >> 16;
    g = (oldColor & 0x0000ff00UL) >> 8;
    b = (oldColor & 0x000000ffUL);
    r=(r<=10)? 0 : (int) r-(r*fadeValue/256);
    g=(g<=10)? 0 : (int) g-(g*fadeValue/256);
    b=(b<=10)? 0 : (int) b-(b*fadeValue/256);
    strip.setPixelColor(ledNo, r,g,b);
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   leds[ledNo].fadeToBlackBy( fadeValue );
 #endif
// *** REPLACE TO HERE ***
// ** FastLed/NeoPixel Common Functions **
// Apply LED color changes
void showStrip() {
   // NeoPixel
   strip.show();
 #endif
   // FastLED
   FastLED.show();
 #endif
// Set a LED color (not yet visible)
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
// Set all LEDs to a given color and apply it (visible)
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
  showStrip();
// ** RGB LED Color Setting **
  setColor(255, 0, 0);  // red
  delay(1000);
  setColor(0, 255, 0);  // green
  delay(1000);
  setColor(0, 0, 255);  // blue
  delay(1000);
  setColor(255, 255, 0);  // yellow
  delay(1000);
  setColor(80, 0, 80);  // purple
  delay(1000);
  setColor(0, 255, 255);  // aqua
  delay(1000);
  setColor(0x48, 0x0, 0x82);  // indigo
  delay(1000);
void setColor(int red, int green, int blue)
  #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    blue = 255 - blue;
  #endif
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
dmnagy6192
Re: RGB Push Button Code
by dastels on Fri Sep 13, 2019 4:42 pm
First, you have anode/cathode mixed up. The product page says it's common anode (1 anode, 3 cathodes)
5v > Common Cathode
Red Anode > PIN11
Green Anode > PIN10
Blue Anode > PIN9
Also, this doesn't even compile. It's the "RGB LED Color Setting" code you pasted in. There's a bare block of code... not a function.
But conceptually you need to have your code doing two things at a time: the neopixel effect and the switch LED colour cycling.
The code as it was written can't do that... a neopixel effect function gets called and plays the effect until it's finished, then returns to loop(). It will pretty much have to be rewritten to do both things. This is an example of concurrent computation.
A side note: The switch is a simple pushbutton, and as such is very noisy. When you push it the contacts will bounce for a brief time before settling into a closed position. You can't use that directly to drive an interrupt since you'll get an interrupt with each bounce. If you want to use an interrupt you'll need to electrically debounce the switch. Easier is to use the debounce2 library to debounce it in software and check it regularly. But that, too, would require rewriting it to be concurrent.
Two books to read, both by Simon Monk, are:
Programming Arduino
Programming Arduino: Next Steps
dastels
