64x64 SmartLED matrix design differs from pics, won't fit Te
by zvonler on Sat Aug 24, 2019 4:51 pm
Hello, I recently purchased the 64x64 SmartLED panel and the SmartLED Teensy Shield, but I have discovered that I am unable to use them together due to what appears to be a manufacturing change to the LED panel.
Compared to the pics of the 'original' at https://www.adafruit.com/product/1902, the panel I received has its DIN and power connectors oriented in such a way that the shield covers the power pins when plugged in. There is also a difference in the plastic frame design around the panel - the one I received has crossbars that also prevent the fitment of the Teensy shield.
Is there an updated shield, or a way I could get the original version of the panel? I bought these parts only to use together and would like to return both if there's not a relatively straightforward path like the product page shows.
zvonler
Re: 64x64 SmartLED matrix design differs from pics, won't fi
by franklin97355 on Sat Aug 24, 2019 5:03 pm
I'll check with supply.
franklin97355
by adafruit2 on Sun Aug 25, 2019 1:35 pm
ooof - all are stock is going to be the same - we dont have much control over what the panels end up being. the best suggestion we have is to desolder/cut off the power connector from the panel and then run the two power wires by hand. not elegant but should work! we'll update the product copy and photo as well. if you cant use them, email support@adafruit for a return label and refund
adafruit2
Site Admin
