Autoscrolling for USB + Serial RGB Backlight Character LCD B
by jessgingery on Sun Aug 25, 2019 4:41 pm
I'm using LCD backpack https://learn.adafruit.com/usb-plus-serial-backpack/usb-or-ttl-serial + Metro board and having issues trying to get the autoscroll to initiate.
The command reference page https://learn.adafruit.com/usb-plus-serial-backpack/command-reference only explains which autoscrolling code to use but not where to locate it, whether it should be in the setup or loop.
I can get the example text to display over the two lines of 16 characters but can't get it to initiate the autoscroll function for even just one statement to work. In the end what I want to accomplish is each statement cycling through and imagine I will need to create an array for the statements so they can be displayed continuously with a time delay in between. I am new to Arduino so be gentle - thank you.
The code we have put together so far is :
//Command Reference for adusting the display
//https://learn.adafruit.com/usb-plus-serial-backpack/command-reference
#include "Arduino.h"
#if defined(ARDUINO_ARCH_SAMD) || defined(__SAM3X8E__)
  // use pin 18 with Due, pin 1 with Zero or M0 Pro
  #define lcd Serial1
#else
  #include <SoftwareSerial.h>
  // Create a software serial port!
  SoftwareSerial lcd = SoftwareSerial(0,2);
#endif
// for ESP8266 use this SoftwareSerial library: https://github.com/plerup/espsoftwareserial
char* message = "Three close friends' profile contain themes identified as dangerous";
int i = 0;
  lcd.begin(9600);
  // set the size of the display if it isn't 16x2 (you only have to do this once)
  lcd.write(0xFE); //Turn LCD display on
  lcd.write(0xD1); //Set LCD size
  lcd.write(16);  // 16 columns
  lcd.write(2);   // 2 rows
  delay(10);
  // we suggest putting delays after each command to make sure the data
  // is sent and the LCD is updated.
  // set the contrast, 200 is a good place to start, adjust as desired
  lcd.write(0xFE);
  lcd.write(0x50); //set display contrast
  lcd.write(200); //display contrast value. 180-220 recommended
  delay(10);
  // set the brightness - we'll max it (255 is max brightness)
  lcd.write(0xFE);
  lcd.write(0x99); //set overall brightness
  lcd.write(255);  //brightness value 0-255
  delay(10);
  // turn off cursors
  lcd.write(0xFE);
  lcd.write(0x4B); //0x4A turns on underline cursor
  lcd.write(0xFE);
  lcd.write(0x53); //0x53 turns on blinking block cursor
  // clear screen
  clearScreen();
  lcd.write(0xFE);
  lcd.write(0x51); /*Autoscroll on - 0xFE 0x51 - this will make it so when text is received and there's no more space on the display,
  the text will automatically 'scroll' so the second line becomes the first line, etc. and new text is always
  at the bottom of the display*/
//  lcd.write(0xFE);
//  lcd.write(0x52); /*Autoscroll off - 0xFE 0x52 - this will make it so when text is received and there's no more space on the display,
//  the text will wrap around to start at the top of the display.*/
  delay(1000);
  lcd.print(message);
uint8_t red, green, blue;
colorBackground();
//clearScreen();
// lcd.write(0xFE);
// lcd.write(0x51); /*Autoscroll on - 0xFE 0x51 - this will make it so when text is received and there's no more space on the display,
// the text will automatically 'scroll' so the second line becomes the first line, etc. and new text is always
// at the bottom of the display*/
void clearScreen() {
 lcd.write(0xFE);
 lcd.write(0x58); //clears the screen of text
 delay(10);
void homeLCD() {
  lcd.write(0xFE);
  lcd.write(0x48); //place cursor at (1,1)
  delay(10);   // we suggest putting delays after each command
//sets the background to cycle through colors
void colorBackground(){
 for (red = 0; red < 255; red++) { //increment brightness
  lcd.write(0xFE);
  lcd.write(0xD0); //sets backlight to red, green, and blue
  lcd.write(red);
  lcd.write((uint8_t)0);
  lcd.write(255 - red);
  delay(10);  // give it some time to adjust the backlight!
 for (green = 0; green < 255; green++) {
  lcd.write(0xFE);
  lcd.write(0xD0);
  lcd.write(255-green);
  lcd.write(green);
 for (blue = 0; blue < 255; blue++) {
  lcd.write(0xFE);
  lcd.write(0xD0);
  lcd.write(255-blue);
  lcd.write(blue);
// adjust colors
// to set backlight to red use 0xD0 0xFF 0x0 0x0
// to set backlight to blue use 0xD0 0x0 0x0 0xFF
// to set backlight to white use 0xD0 0xFF 0xFF 0xFF
/* TEXT TO DISPLAY
Your social media influence is up 0.07%.
Three close friends' profile contain themes identified as "dangerous".
MumsTheWord logged 8 microaggressions in your professional communications last month.
Your resting heart rate is high. Take ashwagandha root from your Nootdial.
Family cohesion is up 3%.
Your resume was read by 3752 bots today. Interviews pending: 0.
Your clickstream analysis shows signs of apathy. Facetime with Marei.
Cortisol level is higher than average. Program forest therapy during down time.
Your WorkDate drink this week is with Dave C and Erykah S. Your conversation topics are "Learning Spanish" and "books you own but haven't read".
//  From previous example stuff we don't need
//  // create a custom character
//  lcd.write(0xFE);
//  lcd.write(0x4E); //create a custom character in spot (can be between 0-7 which is 8 spots)
//  lcd.write((uint8_t)0);     // location #0. uint8_t is a byte. a type of unsigned integer of length 8 bits
//  lcd.write((uint8_t)0x00);  // 8 bytes of character data
//  lcd.write(0x0A);
//  lcd.write(0x15);
//  lcd.write(0x11);
//  lcd.write(0x11);
//  lcd.write(0x0A);
//  lcd.write(0x04);
//  delay(10);   // we suggest putting delays after each command
//  lcd.print("We ");
//  lcd.write((uint8_t)0);            // to print the custom character, 'write' the location
//  lcd.println(" Arduino!");
//  lcd.print("     - Adafruit");
jessgingery
