Bare Conductive touch board & 26 RGB Neopixels
by rachelmax on Wed Sep 04, 2019 8:38 pm
Hello -
I am using the Bare Conductive touch board with conductive paint and 26 RGB neopixels. I have pixel check at the start of my loop and the pixels are all a lovely bright white. In the code I use a button counter to count the number of times a sensor is touched - after 5, the Neopixels light up - but sadly are only a dull orangish - sort of like there's not enough power... but that first pixel check looks great....
Any ideas?
I am running the Neopixels from the 5v (also tried 3V - same issue). no other sensors - just three 30mm circles of conductive paint.
Thank you, Rachel
rachelmax
Re: Bare Conductive touch board & 26 RGB Neopixels
by nickine9 on Thu Sep 05, 2019 2:51 am
although it was some time ago I have used a bare conductive board with 40+ neopixels. are you pixels individual pixels or part of a strip/ring? You could try powering the pixels from an external battery pack (remembering to tie the grounds together). It would help if you could post your code and a picture of your wiring.
nickine9
by rachelmax on Thu Sep 05, 2019 3:11 am
 NTS: seems to work with proximity too - so far I seem to only be able to get maybe duration?
 This sketch is based on Random_Touch_MP3.ino from Bare Conductive which uses code by Jim Lindblom
 and plenty of inspiration from the Freescale Semiconductor datasheets and application notes.
 Bare Conductive code written by Stefan Dzisiewski-Smith and Peter Krige.
 This work is licensed under a MIT license https://opensource.org/licenses/MIT
 Copyright (c) 2016, Bare Conductive
// compiler error handling
#include "Compiler_Errors.h"
#include <math.h>
#define NUMPIXELS  26  // Number of pixels in strand
#define NEOP_PIN 12  // NeoPixel LED strand is connected to this pin
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, NEOP_PIN, NEO_GRB + NEO_KHZ800);
// touch includes
#include <MPR121.h>
#include <Wire.h>
#define MPR121_ADDR 0x5C
#define MPR121_INT 4
// define LED_BUILTIN for older versions of Arduino
#ifndef LED_BUILTIN
#define LED_BUILTIN 13
#endif
//time
unsigned long timeAtLEDon = 0;
long LEDonInterval = 1000.0*60.0*10.0; //1000 milliseconds (1 sec) * seconds in a minute * number of minutes
boolean isOn = false;
//button
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
void setup(){
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
   Serial.begin(9600);
  pinMode(LED_BUILTIN, OUTPUT);
  // initialise the Arduino pseudo-random number generator with
  // a bit of noise for extra randomness - this is good general practice
  randomSeed(analogRead(0));
  if(!MPR121.begin(MPR121_ADDR)) Serial.println("error setting up MPR121");
  MPR121.setInterruptPin(MPR121_INT);
void loop(){
    readTouchInputs();
  //do a quick LED test to show that LEDs work and sketch has been reset
  //made it 3000 so I can get a nice group start up animation
 if (millis() < 3000) {
  colorWipe(strip.Color(255, 255, 255), 30); //white
  colorWipe(strip.Color(0, 0, 0), 30);
void readTouchInputs(){
  if(MPR121.touchStatusChanged()){
    MPR121.updateTouchData();
    if(MPR121.getNumTouches()<=4){
      for (int i=0; i < 12; i++){  // Check which electrodes were pressed
        if(MPR121.isNewTouch(i)){
            //pin i was just touched
            Serial.print("pin ");
            Serial.print(i);
            Serial.println(" was just touched");
            digitalWrite(LED_BUILTIN, HIGH);
            } else {
          if(MPR121.isNewRelease(i)){
            Serial.print(i);
            Serial.println(" is no longer being touched");
            digitalWrite(LED_BUILTIN, LOW);
   if (MPR121.isNewTouch(9)) {
   buttonState = HIGH;
    if (MPR121.isNewRelease(9)) {
   buttonState = LOW;
    if (buttonState != lastButtonState) {
    if (buttonState == HIGH) {
      buttonPushCounter++;
      // Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
//interaction
if (buttonPushCounter >= 5 && MPR121.isNewTouch(1)) {
    for (int i = 0; i <= strip.numPixels() - 1; i++) {
      strip.setPixelColor(i, 100, 100, 100);
  if (buttonPushCounter >= 10) {
      strip.setPixelColor(i, 0, 0, 0);
//  if (!isOn) {
//    if (buttonPushCounter >= 5 && MPR121.isNewTouch(1)) {
//      timeAtLEDon = millis();
//      isOn = true;
//  if (millis() > LEDonInterval + timeAtLEDon) {
//    for (int i = 0; i <= strip.numPixels() - 1; i++) {
//      strip.setPixelColor(i, 0, 0, 0);
//     isOn = false;
  // Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for (uint16_t i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
rachelmax
by rachelmax on Thu Sep 05, 2019 3:12 am
Code is above - not tidy code - but code.
Everything is going directly into the board.
rachelmax
by adafruit_support_mike on Thu Sep 05, 2019 3:29 am
Please post a photo showing your hardware and connections.. that sounds like a power issue.
800x600 images usually work best.
by rachelmax on Wed Sep 11, 2019 3:26 pm
Thank you but I finished the project and am now moving so it's all quite stressful.
I could not get the Neopixels to light correctly.
I will try again at a later date.
Cheers,
Rachel
rachelmax
