LED brightness
LED brightness
by rmfritz3 on Sat Sep 07, 2019 4:05 pm
I'm looking at the light output of LEDs available from Adafruit, and I can only find numbers in millicandelas, which is light output in a particular direction; are values in lumens available?
rmfritz3
Re: LED brightness
by adafruit_support_bill on Sun Sep 08, 2019 7:05 am
Since most of the LEDs in the store are designed for indication or display purposes rather than illumination, there is no manufacturer spec for Lumens.
The conversion to lumens depends on the radiation pattern of the LED. The general formula is 1 lumen = 1 candela per steradian,
If you take a typical clear LED with a 20 degree beam, that translates to 0.095 steradians. So if the led is rated for 1000mcd, (1cd) it will put out 0.095 lumens in that cone.
