TFT LCD Showing Lines Through Images
by dsiee on Sat Sep 07, 2019 10:55 pm
Hi All,
I have a 2.4" Featherwing display which has worked fine using the thermal camera demo sketch, however, it is now showing lines through any BMPs I try to display.
The code is trying out tinyUSB Mass Storage so there are a few things going on:
 products from Adafruit!
 MIT license, check LICENSE for more information
 Copyright (c) 2019 Ha Thach for Adafruit Industries
 All text above, and the splash screen below must be included in
 any redistribution
/* This example demo how to expose on-board external Flash as USB Mass Storage.
 * Following library is required
 *   - Adafruit_SPIFlash https://github.com/adafruit/Adafruit_SPIFlash
 *   - SdFat https://github.com/adafruit/SdFat
 * Note: Adafruit fork of SdFat enabled ENABLE_EXTENDED_TRANSFER_CLASS and FAT12_SUPPORT
 * in SdFatConfig.h, which is needed to run SdFat on external flash. You can use original
 * SdFat library and manually change those macros
#include "SPI.h"
#include "SdFat.h"
#include "Adafruit_SPIFlash.h"
#include "Adafruit_TinyUSB.h"
#include <Adafruit_ImageReader.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#if defined(__SAMD51__) || defined(NRF52840_XXAA)
  Adafruit_FlashTransport_QSPI flashTransport(PIN_QSPI_SCK, PIN_QSPI_CS, PIN_QSPI_IO0, PIN_QSPI_IO1, PIN_QSPI_IO2, PIN_QSPI_IO3);
#else
  #if (SPI_INTERFACES_COUNT == 1)
    Adafruit_FlashTransport_SPI flashTransport(SS, &SPI);
  #else
    Adafruit_FlashTransport_SPI flashTransport(SS1, &SPI1);
  #endif
#endif
Adafruit_SPIFlash flash(&flashTransport);
// file system object from SdFat
FatFileSystem fatfs;
FatFile root;
FatFile file;
// USB Mass Storage object
Adafruit_USBD_MSC usb_msc;
Adafruit_ImageReader reader(fatfs); // Image-reader object, pass in SD filesys
#ifdef ESP8266
   #define STMPE_CS 16
   #define TFT_CS   0
   #define TFT_DC   15
   #define SD_CS    2
#endif
#ifdef ESP32
   #define STMPE_CS 32
   #define TFT_CS   15
   #define TFT_DC   33
   #define SD_CS    14
#endif
#ifdef TEENSYDUINO
   #define TFT_DC   10
   #define TFT_CS   4
   #define STMPE_CS 3
   #define SD_CS    8
#endif
#ifdef ARDUINO_STM32_FEATHER
   #define TFT_DC   PB4
   #define TFT_CS   PA15
   #define STMPE_CS PC7
   #define SD_CS    PC5
#endif
#ifdef ARDUINO_NRF52832_FEATHER /* BSP 0.6.5 and higher! */
   #define TFT_DC   11
   #define TFT_CS   31
   #define STMPE_CS 30
   #define SD_CS    27
#endif
#if defined(ARDUINO_MAX32620FTHR) || defined(ARDUINO_MAX32630FTHR)
   #define TFT_DC   P5_4
   #define TFT_CS   P5_3
   #define STMPE_CS P3_3
   #define SD_CS    P3_2
#endif
// Anything else!
#if defined (__AVR_ATmega32U4__) || defined(ARDUINO_SAMD_FEATHER_M0) || defined (__AVR_ATmega328P__) || \
    defined(ARDUINO_SAMD_ZERO) || defined(__SAMD51__) || defined(__SAM3X8E__) || defined(ARDUINO_NRF52840_FEATHER)
   #define STMPE_CS 6
   #define TFT_CS   9
   #define TFT_DC   10
   #define SD_CS    5
#endif
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// Set to true when PC write to flash
bool changed;
// the setup function runs once when you press reset or power the board
void setup()
  pinMode(LED_BUILTIN, OUTPUT);
  flash.begin();
  usb_msc_setup();
  // Init file system on the flash
  fatfs.begin(&flash);
  Serial.begin(115200);
  while ( !Serial ) delay(10);   // wait for native usb
  tft.begin();
  tft.fillScreen(ILI9341_BLACK);
  delay(1000);
  changed = true; // to print contents initially
  ImageReturnCode stat;
  stat = reader.drawBMP("/parrots.bmp", tft, 0, 0);
  reader.printStatus(stat);
void loop()
  if ( changed )
    changed = false;
    updateChanged();
    delay(2000); // refresh every 2 second
void usb_msc_setup(){
    // Set disk vendor id, product id and revision with string up to 8, 16, 4 characters respectively
  usb_msc.setID("Adafruit", "External Flash", "1.0");
  // Set callback
  usb_msc.setReadWriteCallback(msc_read_cb, msc_write_cb, msc_flush_cb);
  // Set disk size, block size should be 512 regardless of spi flash page size
  usb_msc.setCapacity(flash.pageSize()*flash.numPages()/512, 512);
  // MSC is ready for read/write
  usb_msc.setUnitReady(true);
  usb_msc.begin();
void updateChanged(){
  if ( !root.open("/") )
      Serial.println("open root failed");
      return;
    Serial.println("Flash contents:");
    // Open next file in root.
    // Warning, openNext starts at the current directory position
    // so a rewind of the directory may be required.
    while ( file.openNext(&root, O_RDONLY) )
      file.printFileSize(&Serial);
      Serial.write(' ');
      file.printName(&Serial);
      if ( file.isDir() )
        // Indicate a directory.
        Serial.write('/');
      Serial.println();
      file.close();
    root.close();
    Serial.println();
// Callback invoked when received READ10 command.
// Copy disk's data to buffer (up to bufsize) and
// return number of copied bytes (must be multiple of block size)
int32_t msc_read_cb (uint32_t lba, void* buffer, uint32_t bufsize)
  // Note: SPIFLash Bock API: readBlocks/writeBlocks/syncBlocks
  // already include 4K sector caching internally. We don't need to cache it, yahhhh!!
  return flash.readBlocks(lba, (uint8_t*) buffer, bufsize/512) ? bufsize : -1;
// Callback invoked when received WRITE10 command.
// Process data in buffer to disk's storage and
// return number of written bytes (must be multiple of block size)
int32_t msc_write_cb (uint32_t lba, uint8_t* buffer, uint32_t bufsize)
  digitalWrite(LED_BUILTIN, HIGH);
  return flash.writeBlocks(lba, buffer, bufsize/512) ? bufsize : -1;
// Callback invoked when WRITE10 command is completed (status received and accepted by host).
// used to flush any pending cache.
void msc_flush_cb (void)
  // sync with flash
  flash.syncBlocks();
  // clear file system's cache to force refresh
  fatfs.cacheClear();
  changed = true;
  digitalWrite(LED_BUILTIN, LOW);
dsiee
