PiOLED Not working at all
Re: PiOLED Not working at all
by crashmoon on Sat Dec 28, 2019 4:55 am
aphexx0407 wrote:Run the command ls /dev/i2c* /dev/spi*
You should get a response /dev/i2c-1 /dev/spidev0.0 /dev/spidev0.1
Also make sure you install the Python libraries
Yep, please see all 4 commands and their output in my screenshot. This command came back with the correct output.
I have also rebooted the Pi multiple times, checked that the stats.py is running and it is (see screenshot below) the process comes up twice because I've set it to start at boot and I manually started it as root to see if that worked but still nothing.
crashmoon
by crashmoon on Sat Dec 28, 2019 5:00 am
just for clarity, and being on a new page now:
Also I have a static IP set for the Pi and have set my routers DNS to the same as the Pi's IP address. Like I said initially, the Pi-hole works fine, just no stats (no anything) on my Oled screen
crashmoon
by aphexx0407 on Sat Dec 28, 2019 5:33 am
That's odd, so maybe it is. Have you reseated the PiOLED to the bieard as well?
aphexx0407
by crashmoon on Sat Dec 28, 2019 5:51 am
aphexx0407 wrote:That's odd, so maybe it is. Have you reseated the PiOLED to the bieard as well?
It actually looks like the screen is cracked at the top near the connection
crashmoon
by aphexx0407 on Sat Dec 28, 2019 6:24 am
It does, contact aftersales support. They'd be more than happy to settle that for you
aphexx0407
by crashmoon on Sat Dec 28, 2019 7:04 am
aphexx0407 wrote:It does, contact aftersales support. They'd be more than happy to settle that for you
Willl do. Thanks for your help anyway :)
crashmoon
by adafruit_support_carter on Sat Dec 28, 2019 7:26 pm
@crashmoon It would also help if you could start a new thread for your issue. If support has already taken care of you, then no worries. But in general, it's best to always start a new thread for any new issue.
