I2C Mini Matrix (PID: 870) Random Data
by vader7071 on Tue Sep 10, 2019 12:55 pm
I have a few of the 8x8 mini matrices. I use them for scrolling messages, however, I want to be able to show just random data. Just random LEDs popping on and off.
The overall system will be (6) of the 8x8 mini's (https://www.adafruit.com/product/870) tied together (yes, I am aware that the mini only has 4 addressable slots, so there will be some that show the same thing) and I will have (2) of the 16x8 minis (https://www.adafruit.com/product/3152) on the same data chain showing random data as well.
I can make the 870's and 3152's scroll messages no problem, but what would be the best way to display random LEDs?
Thank you in advance for your help.
vader7071
Re: I2C Mini Matrix (PID: 870) Random Data
by adafruit_support_bill on Tue Sep 10, 2019 1:40 pm
The GFX library has a drawPixel() function for drawing individual pixels.
https://learn.adafruit.com/adafruit-gfx ... points-3-1
And the Arduino library has a random() function for generating pseudorandom numbers:
https://www.arduino.cc/reference/en/lan ... rs/random/
You can specify the maximum range of the numbers to match the dimensions of your array.
by vader7071 on Wed Sep 11, 2019 8:54 am
I think that can help.
But I was wondering if I could just write a random number between 0-2040 to each 8x8 and 0-4080 for the 16x8. I am getting the max value of 2040 by multiplying 255 by 8 columns. (1 column has 8 LEDs, 8 bit Bin to Dec = 255, 255 per column times 8 columns).
My hardware will be (4) of the 8x8 addressed to 0x70-0x73 and (3) of the 16x8 addressed to 0x74-0x76.
I know this code isn't exact, but it shows my idea (it assumes already setting up the various includes and declares for libraries for the matrices).
// -- For the 8x8 Matrices --
  for (int i = 0; i < 4, i++) {
    int data = random(0,2040);
    matrix8[i].clear;
    matrix8[i],print(data);
    matrix8[i].writeDisplay();
// -- For the 16x8 Matrices --
  for (int i = 4; i < 7, i++) {
    int data = random(0,4080);
    matrix16[i].clear;
    matrix16[i],print(data);
    matrix16[i].writeDisplay();
vader7071
by adafruit_support_bill on Wed Sep 11, 2019 9:09 am
The 'print()' command is going to try to print characters. To set random pixels you would either need to use the drawPixel function, or do low-level register operations directly to the HT16K33 chip. Writing to registers would allow you to set up to 8 pixels at a time.
by vader7071 on Wed Sep 11, 2019 3:09 pm
If I used the matrix[i].drawPixel(uint16_t x, uint16_t y, uint16_t color), (is that the proper syntax?) my "x" would be from 0-7 and my "y" would be from 0-7 as well?
So it would look like this:
    int x_pos = random(0,7);
    int y_pos = random(0,7);
    matrix8[i].clear;
    matrix8[i].drawPixel(x_pos, y_pos),
But I would have to create a bunch of those to get a lot of LEDs on at the same time. Otherwise I am looking at 1 LED per matrix.
vader7071
by vader7071 on Wed Sep 11, 2019 3:13 pm
To give an idea of the end result I am looking for, here is a link to a video of the desired result.
https://www.facebook.com/vader7071/videos/10201096871616365/?t=0
I am trying to replicate the 2 LED matrices in the R2 dome.
vader7071
by adafruit_support_bill on Wed Sep 11, 2019 3:26 pm
Your video link is blocked for some reason. But you can call drawPixel as many times as you want per matrix. There is nothing that limits you to 1 pixel.
Coded as below, it should set every pixel on every matrix to either ON or OFF
    matrix8[i].clear;
    for int(row = 0, row < 8, row++)
        for (int col = 0, col < 8, col++)
            matrix8[i].drawPixel(row, col, random(0,2));
by vader7071 on Wed Sep 11, 2019 3:41 pm
https://www.youtube.com/watch?v=SB-kVblAhTI
That link may work better.
So, if I am following your code correctly. you are going to each matrix one at the time.
On a single matrix, you are going to each column, one at the time, and then going to each LED on that column, and using the random generator t determine if that single LED is to be on or off.
So instead of generating a random value of, let's say 673, and writing that whole value to the entire matrix, you are scrolling each and every LED and randomizing on or off.
Interesting.
vader7071
by adafruit_support_bill on Wed Sep 11, 2019 3:53 pm
If you wanted to dig into the library code, you could write 8 at a time directly to the HT16K33 registers. But it is not likely to be any faster. As it is, drawPixel is writing to a memory buffer. That gets flushed to the matrix at the end when you call writeDisplay().
by vader7071 on Wed Sep 11, 2019 6:04 pm
Thank you for your help. I'll be testing this tomorrow.
vader7071
by vader7071 on Thu Sep 12, 2019 8:59 am
    matrix8[i].clear;
Bill, this code worked perfectly. I am currently testing with some of the 8x8 matrices. I will be adding the 16x8 soon.
This is my final code. I call it as a subroutine, and the "millis() - prev_milli[2] >= data_port_delay" is to allow me to slow down or speed up the rate without affecting any of the other sub routines.
void dataDisplay() {
  if (millis() - prev_milli[2] >= data_port_delay){
    // --- 8x8 Matrix ---
    for (int i = 0; i < 4; i++) {
      matrix8[i].clear();
      for (int row8 = 0; row8 < 8; row8++) {
        for (int col8 = 0; col8 < 8; col8++) {
          matrix8[i].drawPixel(row8, col8, random(0,2));
    // --- 16x8 Matrix ---
    for (int c = 4; c < 7; c++) {
      matrix16[c].clear();
      for (int row16 = 0; row16 < 8; row16++) {
        for (int col16 = 0; col16 < 16; col16++) {
          matrix16[c].drawPixel(row16, col16, random(0,2));
      matrix16[c].writeDisplay();
    prev_milli[2] = millis();
vader7071
by adafruit_support_bill on Thu Sep 12, 2019 9:30 am
Good to hear that worked for you. Thanks for the update.
