7-Segment LED Backpack - Can't Address Left Colon or Decimal
by bigrick on Wed Sep 11, 2019 9:50 pm
I'm using the 1.2" 7-Segment LED Backpack to build myself an alarm clock. I want to individually address the two dots of the left colon to use them as indicators. The top dot will be an AM/PM indicator, while the bottom dot will illuminate only when the alarm is armed. The online documentation makes it seem like this should be fairly easy, but I can't figure it out for the life of me.
I am using an Arduino Uno Wifi Rev 2 and my libraries are up to date. Below is my code, which I modified from the seven segment example sketch included in the Adafruit_LEDBackpack library. I've cut out the parts that aren't relevant to the problem I'm having.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
Adafruit_7segment matrix = Adafruit_7segment();
#ifndef __AVR_ATtiny85__
  Serial.begin(9600);
  Serial.println("7 Segment Backpack Test");
#endif
  matrix.begin(0x70);
  matrix.writeDigitNum(2, 0x02);
  matrix.writeDisplay();
The documentation says that when I run this code, only the middle colon should light up. While I do get the middle colon, the bottom dot of the left colon and the upper right "decimal point" also light up.
When I change "0x02" to "0x04", the lower dot of the left colon should light up, but instead I get the middle colon and the upper dot of the left colon. When I use 0x08, I get all the dots lighting up instead of just the upper dot of the left colon. 0x10 causes the entire display to go blank. For what it's worth, the drawColon(true/false) function works as it's supposed to.
I own three of these LED backpacks for testing and I'm getting the same result with all of them. I tried swapping the WiFi Rev 2 out with a standard Arduino Uno and got the same result. It doesn't seem to be a hardware issue. Does anyone have any idea where I can start tackling this problem? I'm pretty baffled. Picture of my setup and result below for your reference. Thanks.
Screen Shot 2019-09-11 at 9.41.17 PM.png (692.57 KiB) Viewed 80 times
bigrick
Re: 7-Segment LED Backpack - Can't Address Left Colon or Dec
by kcl1s on Thu Sep 12, 2019 6:27 am
From the backpack guide
To control the colon and decimal points, use the writeDigitRaw(location, bitmap) function.
You are using writeDigitNum
Fellow hobbyist
Keith
kcl1s
by bigrick on Thu Sep 12, 2019 7:30 pm
Wow, duh. Can't believe that was it. Thank you so much!!
bigrick
