Only first 7 are lighting up on Neopixel Strip
by AirBubblesCosplay on Thu Sep 12, 2019 3:54 am
Hey everyone! I started a project a few months ago and had to put it aside. I've recently picked it back up again and for some reason only the first 7 of the neopixels in the strip will light up. I've tripled checked the number and I definitely have typed out more than 7 LED's. I'm at a loss.
I'm doing this all through USB as the final project will be run via an external battery/phone charger thing.
And yes, the whole thing worked a few months ago when I was first playing with it.
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 4
#define N_LEDS 77
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 – 500 Ohm resistor on first pixel’s data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit…if you must, connect GND first.
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
strip.begin();
strip.show(); // Initialize all pixels to ‘off’
int r = 255;
int g = 96;
int b = 12;
for(int x = 0; x <30; x++)
int flicker = random(0,40);
int r1 = r-flicker;
int g1 = g-flicker;
int b1 = b-flicker;
if(g1<0) g1=0;
if(r1<0) r1=0;
if(b1<0) b1=0;
strip.setPixelColor(x,r1,g1, b1);
strip.show();
delay(random(50,150));
AirBubblesCosplay
Re: Only first 7 are lighting up on Neopixel Strip
by adafruit_support_bill on Thu Sep 12, 2019 6:12 am
If you place the strip on a flat surface and press down on pixels #6, 7 and 8, do you see any activity on the rest of the strip?
