Snake eyes only on one screen (not two!)
by nanikore on Mon Sep 23, 2019 7:12 am
Hi.
I got my Snake Eyes kit delivered recently, the bonnet, cables and 2x 240*240pixel IPS TFT screens, hooked up to my Raspberry Pi 3, 16GB SD. I was following this guide:
https://learn.adafruit.com/animated-sna ... i/overview
After initial build and install it boots, and on my HDMI connected screen I see the two creepy eyes (success)! However, I only see an eye on the left LCD screen (also see boot text on this screen only during boot, but I suspected that was working as designed).
The backlights come on for both, so the right hand screen is getting something. I swapped the LCDs over, and could get an image on the other screen, so I know the LCDs are OK. I checked the cabling, and it looks OK. This led me to think the issue was one of my solders, so my next task is to get my multimeter on those.
Can anyone recommend any tests, diagnostics or logs I can be checking to try to fix this?
(Hoping to deploy this as part of a Halloween animatronic in front of the house.)
nanikore
Re: Snake eyes only on one screen (not two!)
by nanikore on Wed Sep 25, 2019 10:02 am
Checked all the connections on my multimeter... no joy. Seems there's something wrong with the bonnet?
Adafruit, what's next? Running out of time for a cool Halloween animatronic :(
nanikore
by nanikore on Wed Sep 25, 2019 8:21 pm
Is in the right sub-forum then if the screens seemingly work work? Is 'Other Products from Adafruit' the correct sub-forum? Should I re-post there or can this be moved?
nanikore
by nanikore on Fri Sep 27, 2019 9:19 pm
I tried making some changes on the tutorial page, such as variations:
sudo ./fbx2 -i -b 10000000
but that doesnt appear to work either.
nanikore
by Jackjohnjoseph on Sun Jan 03, 2021 11:10 pm
I see you did not get any response, you might need pictures or something.
Jackjohnjoseph
by nanikore on Mon Jan 04, 2021 3:00 am
I did get a fix in another subforum - let me see if I can get this thread marked fixed.
https://forums.adafruit.com/viewtopic.php?f=50&t=156923
nanikore
