64x64 RGB LED Matrix - 2.5mm Pitch technical drawing
by rynfox13 on Tue Oct 01, 2019 11:42 am
I was wondering if there's a mechanical drawing for the screw points and protrusions on the 64x64 RGB LED Matrix with 2.5mm pitch (#3649)? Or, at least, measurements for the screw point centers and for the two protrusions? Specifically, I'm trying to build a sign frame and need to know where the screw points are on it for proper placement. I got the dimensions off the website (160mm by 160mm); however, I need the dimensions and locations for the screw posts and my equipment can't quite get it right for the 3D print.
These are the screws and protrusions I would like measurements on.
rynfox13
Re: 64x64 RGB LED Matrix - 2.5mm Pitch technical drawing
by parentevan on Thu Nov 14, 2019 11:13 am
I'd also like to see more data on the physical dimensions of this screen so that I may build an enclosure. Has anything come of this?
parentevan
by Khughes2000 on Sat Nov 23, 2019 8:23 pm
I would also like some kind of template to be able to transfer the location of the mounting points to a device to mount the LED to.
Could someone trace the back of the unit and mark the holes and the plastic nubs and scan to pdf and send it to me. My son has this in Texas, but I live in Missouri and I’m trying to make a surprise background to mount it to.
Thanks.
Khughes2000
Khughes2000
by parentevan on Sat Nov 23, 2019 10:44 pm
I’ll work on this over the next couple days. I put calipers to mine and measurements were coming out in 1mm increments.
parentevan
by franklin97355 on Sun Nov 24, 2019 12:20 am
These are surplus from sign manufacturers so the dimensions may change at any time.
franklin97355
by Khughes2000 on Sun Nov 24, 2019 6:33 pm
parentevan wrote:I’ll work on this over the next couple days. I put calipers to mine and measurements were coming out in 1mm increments.
Thanks, I can't measure it, cause they are in Texas, I am in Missouri.
Khughes2000
