Product 618 mating connector
by System__control on Tue Oct 01, 2019 2:39 pm
Looking for information on the meeting connector for product 618. I know it is a Zif connector requiring 14 contacts but the footprint of the cable is wider then the 14 contacts. Is it a 30 (14) loaded? Can you provide connector specs.
System__control
Re: Product 618 mating connector
by franklin97355 on Tue Oct 01, 2019 3:24 pm
It is for surface mount and would need to be soldered to a circuit board.
Please note! This is just the raw display, not attached to a PCB or for use with a breadboard. If you want to use this out of the box with no surface mount soldering, check out our fully assembled 1.8" TFT breakout board with microSD card holder. This display is for experts who are comfortable soldering a surface mount display using fine pitch soldering techniques! This display also is for 3.3V use only, so be sure to use a level shifter if you're going to use it with 5.0V microcontrollers.
franklin97355
