Dotstar RGB issues
Dotstar RGB issues
by mitch33333 on Wed Oct 09, 2019 11:08 pm
Hi, It looks like my Dotstar strip has the the RGB switched around. I can get decent colors by taking RGB values by using
strip.Color(0,255,0);
but would prefer to use
ColorHSV(0,255,50);
. It seems I have (GRB) which gives me very incorrect results when trying to use ColorHSV(). Does anyone have a way to use ColorHSV with (G,R,B) so I can find more accurate colors?
Also, I'm using at ATTiny85 for this project.
mitch33333
Re: Dotstar RGB issues
by adafruit_support_carter on Thu Oct 10, 2019 3:28 pm
Are you using the DotStar library?
https://github.com/adafruit/Adafruit_DotStar
by mitch33333 on Thu Oct 10, 2019 3:40 pm
Yes I am, But I got it using the dotstar uberguide and not GitHub. These should be the same either way though, right?
mitch33333
by adafruit_support_carter on Thu Oct 10, 2019 4:08 pm
Yep. Should be the same thing. If you installed via the Arduino Library Manager, then you got whatever the latest release is from that GitHub repo.
The internal mapping of the colors, like RGB vs GRB should be handled by the library. You specify what you have when you create the DotStar object:
https://github.com/adafruit/Adafruit_Do ... tar.h#L104
So if you have GRB, then use DOTSTAR_GRB.
After that you can think in terms of RGB for all the library functions. The actual color order will be mapped internally by the library.
