NeoPixel LED strip does not light up
by stapelberg on Sat Nov 09, 2019 2:00 pm
I bought https://www.adafruit.com/product/2562 (product 2562) and connected it to an https://store.arduino.cc/arduino-nano-33-ble (Arduino Nano 33 BLE) like in the attached wiring picture (Din on D6, red power on 3.3V, black power on GND). The starter pack contains a 1m strip with 30 LEDs.
I’m using a 5V 8A USB power supply from Anker to power the Arduino Nano 33 BLE.
As you can see in the picture, I measure 3.3V on the output end of the strip, so power is connected correctly and flowing.
I have verified that D6 is toggled high/low when toggling pin 6 in the arduino IDE.
I have verified that the input/output side is correct by testing it on either side, and it works in neither config. Also, the label clearly says Din, and the arrow is pointing toward the LED, so I’m fairly certain I got it connected right.
This is the test program I’m using:
// Simple NeoPixel test.  Lights just a few pixels at a time so a
// 1m strip can safely be powered from Arduino 5V pin.  Arduino
// may nonetheless hiccup when LEDs are first connected and not
// accept code.  So upload code first, unplug USB, connect pixels
// to GND FIRST, then +5V and digital pin 6, then re-plug USB.
// A working strip will show a few pixels moving down the line,
// cycling between red, green and blue.  If you get no response,
// might be connected to wrong end of strip (the end wires, if
// any, are no indication -- look instead for the data direction
// arrows printed on the strip).
#define PIN      6
#define N_LEDS 30
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
  chase(strip.Color(255, 0, 0)); // Red
  chase(strip.Color(0, 255, 0)); // Green
  chase(strip.Color(0, 0, 255)); // Blue
static void chase(uint32_t c) {
  for(uint16_t i=0; i<strip.numPixels()+4; i++) {
      strip.setPixelColor(i  , c); // Draw new pixel
      strip.setPixelColor(i-4, 0); // Erase pixel a few steps back
      strip.show();
      delay(25);
At this point, I’m wondering if the strip might be defective?
I have tried connecting the strip to the 5V power supply that was included in the starter kit, but it doesn’t light up either.
stapelberg
Re: NeoPixel LED strip does not light up
by kcl1s on Sat Nov 09, 2019 7:28 pm
Can you post a photo of where the signal wire enters the strip showing the strip pcb markings? The signal should be on the DIN end not the Dout end of the strip.
Fellow hobbyist
Keith
kcl1s
by adafruit_support_carter on Mon Nov 11, 2019 3:40 pm
Does your strip have wires on both ends? Another photo verifying the input direction would help.
by stapelberg on Mon Nov 11, 2019 6:41 pm
adafruit_support_carter wrote:Does your strip have wires on both ends?
Yes.
adafruit_support_carter wrote:Another photo verifying the input direction would help.
Here you go:
https://photos.app.goo.gl/iNR1FqFjqJMTft3R7
As I mentioned in the original post, I have tried both ends, and neither works.
stapelberg
by adafruit_support_carter on Tue Nov 12, 2019 12:41 pm
This is the correct end to use. The key is to look for the arrow which indicates the direction of data flow along the strip:
It may be power related. That 3.3V is probably the output of the on board voltage regulator. So it's not going to pass all of the current from your 5V supply.
Do you have any other Arduino boards?
by stapelberg on Tue Nov 12, 2019 3:47 pm
Turns out my girlfriend had an Arduino Uno lying around, which uses 5V, and with which the NeoPixel works indeed.
So it seems like I can’t use it with an Arduino Nano 33 BLE as-is; that’s too bad :-/
Thanks for walking me through this.
stapelberg
by adafruit_support_carter on Tue Nov 12, 2019 6:30 pm
Keep trying. NeoPixels are essentially 5V devices, but can be used with 3.3V boards. Lots of info here in the uberguide:
https://learn.adafruit.com/adafruit-neopixel-uberguide
by oesterle on Thu Nov 21, 2019 2:49 pm
Hi, BigMike81!
Welcome to the Forums!
Please start a new topic with your issue. We encourage this since projects and their troubleshooting steps vary.
Cheers,
Eric
oesterle
