Are these two 8x16 LED Matrix backpacks functionally identic
by BlinkyKB on Tue Nov 19, 2019 1:49 am
Other than the fact that one will directly mount 2x 8x8 matrices and the other will not, are these two backpacks functionally the same?:
Adafruit 16x8 LED Matrix Driver Backpack - HT16K33 Breakout
PRODUCT ID: 1427
https://www.adafruit.com/product/1427
and
Adafruit 8x16 LED Matrix FeatherWing w/o Matrices
PRODUCT ID: 3090
https://www.adafruit.com/product/3090
I want to use several backpacks to create a large dot matrix display, and I want to run it through I2C from a Grand Central using CircuitPython, can I do that?
And, can I control the brightness? The example code suggests I can but the product description of the non-featherwing backpack says, "Note that the driver can turn LEDs on and off but does not have the ability to individually PWM dim them." So, I am confused....
Thanks in advance for the help!
BlinkyKB
Re: Are these two 8x16 LED Matrix backpacks functionally ide
by dastels on Tue Nov 19, 2019 12:07 pm
Yes. Look at the schematics. The only real difference is the LED array and the feather connections.
dastels
by BlinkyKB on Tue Nov 19, 2019 12:10 pm
dastels wrote:Yes. Look at the schematics. The only real difference is the LED array and the feather connections.
Ok, thank you.
BlinkyKB
by adafruit_support_carter on Tue Nov 19, 2019 2:33 pm
As another option, there's a double backpack version for the 1.2" LED matrices. Various colors, square or round pixels, see here:
https://www.adafruit.com/category/326
You can control brightness globally, but not per pixel.
If you want individual pixel brightness control, consider the charlieplexed options:
https://learn.adafruit.com/i31fl3731-16 ... led-driver
by BlinkyKB on Tue Nov 19, 2019 2:45 pm
adafruit_support_carter wrote:As another option, there's a double backpack version for the 1.2" LED matrices. Various colors, square or round pixels, see here:
Great! Thanks for the tips. That driver you linked looks perfect for my needs.
BlinkyKB
cron
