🎁📬❄️📦Adafruit Holiday Shipping Deadlines 2019: Please place all UPS 2 Day orders by 11am Monday, December 16 📦❄️📬🎁
LED strip power injection
by zxarr on Tue Nov 19, 2019 4:18 pm
I'm wondering if there are better ways to inject power in the middle of an LED strip without just soldering onto the pads?
I am looking at making a continuous strip of NeoPixel LED strips (30 LED/m) with no visible gaps between LED's where they're joined; a total of 40 feet. I was hoping they'd invented a simple clip that could be attached in the middle of a strip, over the pads, to inject power. As I'm placing this all in a channel, it'd be better to clip a few places on the strip, rather than solder while atop a ladder.
Thanks.
zxarr
Re: LED strip power injection
by oesterle on Tue Nov 19, 2019 8:13 pm
Since you're looking at 12m+, I'd consider using a continuous run of power and ground cables, soldered to the strip every 1-2m. I don't know of an off-the-shelf clip system compatible with the garden-variety 3-conductor NeoPixel strips, but I'm sure someone makes one.
I've used silicone-insulated stranded copper wire for this. I'd estimate max current requirements, add some headroom, and select from available wire gauges accordingly. You're likely looking at a much larger gauge of wire than Adafruit sells.
Silicone-insulated wire, IMHO, is a great choice for this, since it's super flexible – it's not fighting your strip layout – and more heat resistant, which is important on larger LED projects.
I often refer to the excellent Adafruit NeoPixel Überguide for best practices on power and larger projects, especially these sections:
oesterle
by zxarr on Wed Nov 20, 2019 4:57 pm
Thanks very much!
I'll have a good read through that.
zxarr
