Higher output/multiple EL inverter and wiring
by darksunrise957 on Wed Nov 27, 2019 4:25 am
Hello, I'm working on a project that will require just under 200cm2 combined (4 panels, different sizes) of EL panel, but the only inverters I see here support up to 100cm2. There's also a secondary (MUCH less demanding) EL wire section I was already planning on running off a separate inverter for control simplicity. This would mean I'd need 3 inverters running off the same battery.
Would there be any issues with running all three off the same power supply? And/Or is there a specific way to wire it (parallel, series, resistors, etc.)? Would it be possible to modify a single 12V inverter to run 200cm2 at full brightness? I'm assuming you couldn't give me a link to a supplier of a higher power one (this being the Adafruit forums and all), but I already need some stuff from here, so I would be fine using the three inverter plan.
Final question: I intend on controlling it through an arduino switching the current on/off BEFORE the inverter, to avoid the no-load issues, and whatever may come with controlling AC currents. Most likely using a mosfet or relay, though I'm not familiar enough with it to do it off the top of my head. Is there a proper/specific way to wire it?
Thanks very much; I need all the help I can get with this :)
darksunrise957
Re: Higher output/multiple EL inverter and wiring
by adafruit_support_bill on Wed Nov 27, 2019 7:03 am
There is no problem running multiple inverters from the same battery - as long as the battery is capable of delivering sufficient current.
For switching them on and off, a Darlington array is the most compact solution for multiple channels; https://www.adafruit.com/product/970
But MOSFETs are much more efficient power-wise.: https://www.adafruit.com/product/355
Wiring would be the same as for LED strips as in the 3-channel RGB example shown here: https://learn.adafruit.com/rgb-led-strips/usage
There are higher-capacity inverters out there. I don't have any experience with them, but there are several sites online specializing in EL wire, tape and panels that carry them.
by darksunrise957 on Sun Dec 01, 2019 3:34 am
Whoops, missed your reply. Thank you for your help. I'll keep this in mind.
darksunrise957
