16x32 with hat: just showing green strip of lights at top
by incircles on Fri Nov 29, 2019 5:07 pm
Hi! I'm a novice at circuitry and I'm having issues with the 16x32 matrix on my Raspberry Pi 4. When I power it on, I see either the first two rows or the third row in green all the way across. This is true whether or not it's connected to the Pi. When I run one of the demos (e.g. sudo ./demo -t 10 -D 1 runtext.ppm), I see another row flashing green. Nothing resembling what I should be seeing. Any ideas?
incircles
Re: 16x32 with hat: just showing green strip of lights at to
by incircles on Fri Nov 29, 2019 5:33 pm
Interestingly, the wiring seems to be so sensitive that just moving my hand in the air above the hat will cause random lines to illuminate on the LED board. Almost always a full horizontal line, though.
incircles
by dastels on Fri Nov 29, 2019 5:41 pm
Exactly what hardware are you using (products IDs would be the most useful).
dastels
by incircles on Sun Dec 01, 2019 10:58 am
Medium 16x32 RGB LED matrix panel[ID:420]
Adafruit RGB Matrix HAT + RTC for Raspberry Pi - Mini Kit[ID:2345]
incircles
by dastels on Sun Dec 01, 2019 12:21 pm
One more question... how are you powering the matrix?
dastels
by incircles on Sun Dec 01, 2019 6:04 pm
i stripped the red and black ends of the power cord and plugged them into the + and - ends of a converter, respectively, then plugged a 5v adapter into said converter.
incircles
by dastels on Sun Dec 01, 2019 7:37 pm
What do you mean by "converter"? That matrix takes 5v, yes?
dastels
by incircles on Mon Dec 02, 2019 2:13 pm
Here's a pic. I believe that was the recommended power supply!
incircles
by dastels on Mon Dec 02, 2019 2:33 pm
OK, by converter you mean the barrel/screw-terminal thing.
You've double checked the polarity?
dastels
by incircles on Mon Dec 02, 2019 3:41 pm
The polarity should be correct. I was thinking about trying to reverse it out of curiosity, but I was worried I might damage the board.
incircles
by dastels on Mon Dec 02, 2019 4:50 pm
Best case that there is some protection onboard. I don't see schematics of the LED panel, itself, so I have no idea if that's the case. Worst case if goes poof!
One final thing. You've double & triple checked the connection between the hat & the panel? Those connectors are right way 'round? It shouldn't be possible to have them otherwise since the connectors on the boards are keyed, but if the cable isn't ...
Double check and let me know.
dastels
by Chris_Woollard on Thu Dec 26, 2019 3:03 pm
Hi Dave,
I guess I'm suffering the same sort of problem as incircles is experiencing.
Quick breakdown of symptoms:
Continuous pink[ish] strip of leds on row 2 and a blue strip of leds on row 9 that don't clear upon running a demo OR...
issuing a CTRL-C to exit any demo.
Panel size: 16x32 (ADA420) running via a matrix bonnet (ADA 3211) with its own 5v 4Amp supply on an RPi4 B (4Gb) with its own 3v supply. The Hub75 cable has been inserted correctly into the input socket on the panel.
The pi has been updated to buster.
The broadcom sound module [snd_bcm2835] has been switched off at boot.
If I run any of the demos, I'll see a flicker of led action on rows 3 & 10 until timeout of the demo or exiting using CTRL-C. Then the pink(ish) strip on row 2 and the blueish strip on row 9 reappears.
Regards
Chris_Woollard
by dastels on Thu Dec 26, 2019 3:13 pm
Chris_Woollard Please start a new thread with this.
dastels
by Chris_Woollard on Thu Dec 26, 2019 3:34 pm
noted. separate thread started,
regards
Chris_Woollard
