PiTFT 2.8" Capacitive touch not working
by Weasy on Wed Dec 11, 2019 11:00 am
Hi guys!
I'm trying to get the display to work with the newest Volumio image 2.673. I used the easy install script and in combination with the volumio plugin "Touch display" i got the screen working, but touch is not. I get the following error with 'dmesg':
edt_ft5x06 1-0038: touchscreen probe failed
edt_ft5x06: probe of 1-0038 failed with error -121
After that i wanted to be sure that the problem is not with the volumio image and installed 2019-04-08-raspbian-stretch.
But there i get the same error, here the dmesg output:
[    0.648161] usbcore: registered new interface driver usbhid
[    0.648166] usbhid: USB HID core driver
[    0.648883] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[    0.650259] [vc_sm_connected_init]: start
[    0.658892] [vc_sm_connected_init]: end - returning 0
[    0.659503] Initializing XFRM netlink socket
[    0.659527] NET: Registered protocol family 17
[    0.659620] Key type dns_resolver registered
[    0.660156] Registering SWP/SWPB emulation handler
[    0.660729] registered taskstats version 1
[    0.666492] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.666563] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    0.668286] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    0.668295] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    0.732161] sdhost: log_buf @ bad07000 (fad07000)
[    0.770847] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.772413] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.773965] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.776745] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.811573] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.812605] of_cfs_init
[    0.812740] of_cfs_init: OK
[    0.813242] Waiting for root device PARTUUID=3605f96c-02...
[    0.852781] random: fast init done
[    0.861630] Indeed it is in host mode hprt0 = 00021501
[    0.952274] mmc1: new high speed SDIO card at address 0001
[    0.991322] mmc0: host does not support reading read-only switch, assuming write-enable
[    0.995219] mmc0: new high speed SDHC card at address e624
[    0.995630] mmcblk0: mmc0:e624 SU32G 29.7 GiB
[    0.998696]  mmcblk0: p1 p2
[    1.035032] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.035089] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.035972] devtmpfs: mounted
[    1.039403] Freeing unused kernel memory: 1024K
[    1.071572] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.072008] Indeed it is in host mode hprt0 = 00001101
[    1.311905] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    1.311919] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.312538] hub 1-1:1.0: USB hub found
[    1.312629] hub 1-1:1.0: 5 ports detected
[    1.477250] systemd[1]: System time before build time, advancing clock.
[    1.599729] NET: Registered protocol family 10
[    1.600779] Segment Routing with IPv6
[    1.625325] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.631590] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.644192] random: systemd: uninitialized urandom read (16 bytes read)
[    1.649953] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    1.650515] systemd[1]: Detected architecture arm.
[    1.651718] systemd[1]: Set hostname to <raspberrypi>.
[    1.687284] random: systemd: uninitialized urandom read (16 bytes read)
[    1.717339] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[    1.761968] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    1.761983] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.764637] smsc95xx v1.0.6
[    1.864955] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fe:69:43
[    2.125511] systemd[1]: Listening on udev Control Socket.
[    2.126037] systemd[1]: Listening on udev Kernel Socket.
[    2.148224] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.148675] systemd[1]: Listening on Journal Socket.
[    2.149519] systemd[1]: Created slice System Slice.
[    2.152593] systemd[1]: Mounting Debug File System...
[    2.153721] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    2.234735] i2c /dev entries driver
[    2.719879] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    2.808462] systemd-journald[93]: Received request to flush runtime journal from PID 1
[    3.395409] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    3.402041] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[    3.476039] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    3.485741] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[    3.486023] usbcore: registered new interface driver brcmfmac
[    3.728811] edt_ft5x06 1-0038: touchscreen probe failed
[    3.729060] edt_ft5x06: probe of 1-0038 failed with error -121
[    3.746441] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[    3.747384] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[    3.768132] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[    3.780606] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[    3.781397] fbtft_of_value: buswidth = 8
[    3.781407] fbtft_of_value: debug = 0
[    3.781414] fbtft_of_value: rotate = 270
[    3.781421] fbtft_of_value: fps = 30
[    3.969247] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=33, spi0.0 at 64 MHz
[    4.538626] uart-pl011 3f201000.serial: no DMA platform data
[    4.826983] random: crng init done
[    4.827013] random: 7 urandom warning(s) missed due to ratelimiting
[    5.273092] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    5.273121] brcmfmac: power management disabled
[    5.603629] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    5.604030] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.792131] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    7.007023] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xDDE1
[    7.009269] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    8.990771] Bluetooth: Core ver 2.22
[    8.990847] NET: Registered protocol family 31
[    8.990853] Bluetooth: HCI device and connection manager initialized
[    8.990874] Bluetooth: HCI socket layer initialized
[    8.990887] Bluetooth: L2CAP socket layer initialized
[    8.990927] Bluetooth: SCO socket layer initialized
[    9.010044] Bluetooth: HCI UART driver ver 2.3
[    9.010058] Bluetooth: HCI UART protocol H4 registered
[    9.010064] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    9.010301] Bluetooth: HCI UART protocol Broadcom registered
[    9.211308] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.211318] Bluetooth: BNEP filters: protocol multicast
[    9.211333] Bluetooth: BNEP socket layer initialized
[    9.259855] Bluetooth: RFCOMM TTY layer initialized
[    9.259885] Bluetooth: RFCOMM socket layer initialized
[    9.259903] Bluetooth: RFCOMM ver 1.11
[   13.760321] fuse init (API version 7.26)
So...how do i make this work?
Don't know if it's helpful, but here is an image of the back of my PiTFT
EDIT: Oh...and i'm using a Raspberry 3 B
Weasy
Re: PiTFT 2.8" Capacitive touch not working
by Weasy on Mon Dec 23, 2019 5:25 pm
@Support can you please help me?
Weasy
