Display appears washed out
by Rktakahashi on Thu Dec 12, 2019 12:18 pm
Hi!
I am having problems with my recently purchased 10.1" Display & Audio 1280x800 IPS - HDMI/VGA/NTSC/PAL[ID:1694] appearing washed out. I have tried multiple times to adjust the display settings with no avail. I was wondering if it is the connector as it appears shorter then the number of pins on the board. I followed the photo on the website to set it up and no other orientation of the cable seems to be successful.
I have also tried multiple HDMI cables with no luck.
Could you please help me in making this work?
Thank you so much!
Randall
Rktakahashi
Re: Display appears washed out
by Rktakahashi on Fri Dec 13, 2019 1:59 pm
Can I start a return for the screen?
Rktakahashi
by adafruit_support_carter on Thu Jan 09, 2020 12:15 pm
Sorry for delay in getting back to you on this.
From your photos, the display appears connected correctly. What is is the actual video source for the HDMI signal?
by Rktakahashi on Fri Jan 10, 2020 2:16 pm
I have tried an msi laptop directly and a pc straight from the back of each. They both normally output to monitors with great resolution.
I have already returned this item, by the way.
Rktakahashi
