Reversing Strip
Reversing Strip
by wiremonkey on Thu Dec 12, 2019 7:17 pm
I have searched a bit but cannot seem to find an answer to this problem. I have a strip 60 count strip of neopixels and am using a potentiometer to fill in the strip. The program is working great but because of the way I have to configure the LEDs I need to reverse the order the strip gets filled. Instead of starting to fill from the DI side I want it to fill from the DO side on the other side of the strip.
Is that possible to do with the code I have?
  //Turn on correct number of LEDs based on numOn
  for (int i = 0; i < 60; i++) {
    if (i < numOn+1) { //the +1 keeps one LED on at all times
      strip_1.setPixelColor(i, 0, 25, 255);  // turn on this LED, also adjusts colors
  ); //turn on this LED, adjust values to affect colors and brightness of LEDs
    else {
      strip_1.setPixelColor(i, 0, 0, 0); //turn off this LED
  strip_1.show(); //Apply changes to Strip
I've tried to replace this
With this
for (int i = 60; i > 0; i--)
but that didn't seem to work.
Thank you for any help.
wiremonkey
Re: Reversing Strip
by adafruit_support_bill on Thu Dec 12, 2019 7:46 pm
Try changing this line:
if (i < numOn+1)
to:
if (i > (60 - numOn))
Re: Reversing Strip
by wiremonkey on Thu Dec 12, 2019 8:04 pm
YES! That did it. Thank you very much!
wiremonkey
Re: Reversing Strip
by adafruit_support_bill on Thu Dec 12, 2019 8:05 pm
Great! Happy hacking.
