createChar with LCD Backpack
by 762spr on Sun Dec 15, 2019 4:29 am
What is the proper usage of createChar with the I2C/SPI character LCD backpack?
I am getting strange results if I try:
uint8_t full[8] = {0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f};
lcd.begin(16, 2);
lcd.print("text");
lcd.createChar(0,full);
lcd.print((char)0);
lcd.print("text2");
lcd.setBacklight(HIGH);
The screen will only show "text". However if I thin comment out lcd.createChar(0,full); and re upload, the screen will show "text" the full character, and "text2".
It's like the character is being written to the memory but then the program hangs. With a soft reset, it seems to retain the custom character in memory and can then read it. If I unplug the board and wait, then plug it back in, the custom character reverts to default.
Is this a bug or am I doing something wrong?
Thanks.
762spr
Re: createChar with LCD Backpack
by adafruit_support_carter on Mon Dec 16, 2019 8:02 pm
Try using the regular serial monitor as a quick test. So add something like a
Serial.println("test");
after your call to createChar and see if it still seems to be hanging.
