40pin TTL Adapter
40pin TTL Adapter
by sixtimesseven on Tue Dec 17, 2019 6:42 pm
Hi
I'm looking for a way to adapt an 18bit RGB TTL panel from a Lecroy Wavemaster Oscilloscope to be driven by a more modern interface (HDMI, DP, LVDS or similar).
The display has a touch screen etc so it could be changed but I hope there is an easier way.
The actual display: http://www.spectrah.com/german/product/ ... minary.pdf
So, I found the "Adafruit TFP401 HDMI/DVI Decoder to 40-pin TTL Display" https://www.adafruit.com/product/2218
Which converts HDMI to TTL which would be perfect with one exception, it outputs 24bit TTL....
Is there a way on the board to change that?
Thank you so much!
sixtimesseven
