3.5" TFT does not respond to rotate.
by eqrunner on Mon Dec 23, 2019 8:15 pm
I am in the beginning stages of trying to make a display with a new 3.5 TFT screen.
Ran the stock graphicstest script for this HX8537 screen. It works fine. But when I try to change anything, (say commenting out a single tft.println) the colors will shift. So I have stripped down all the code to something basic to work with and have introduced a new issue. Rotation. I have changed the value for tft.setRotation() from 0, 1, 2, and 3. and the screen does not change rotation.
What is wrong?
  This is our library for the Adafruit HX8357D Breakout
  ----> http://www.adafruit.com/products/2050
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_HX8357.h"
// These are 'flexible' lines that can be changed
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8 // RST can be set to -1 if you tie it to Arduino's reset
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
// SoftSPI - note that on some processors this might be *faster* than hardware SPI!
//Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, MOSI, SCK, TFT_RST, MISO);
  Serial.begin(9600);
  Serial.println("HX8357D Test!");
  tft.begin();
  // tft.setRotation(2);
  tft.setRotation(1);
  //tft.invertDisplay(0);
  tft.setAddrWindow(0, 0, 320, 480);
  delay(1000);
  tft.fillScreen(HX8357_BLACK);
  delay(1000);
void loop(void) {
  //tft.setRotation(3);
  //tft.setCursor(0, 0);
  //tft.setTextColor(0xCCCC);
  //tft.setTextSize(3);
  tft.println("Hello World!");
  Serial.print("RDMADCTL  ");
  Serial.println(HX8357_RDMADCTL, HEX);
  delay(1000);
eqrunner
Re: 3.5" TFT does not respond to rotate.
by eqrunner on Thu Dec 26, 2019 8:32 pm
SOLVED:
Was using v1.7.2 Adafruit_GFX.h. This version is broken. Use v 1.5.3 and it rotation works great!
Thanks to this post for answers: https://github.com/adafruit/TFTLCD-Library/issues/37
eqrunner
