Question for NeoPixel Ring
by cwcorbin on Wed Jan 08, 2020 8:18 pm
https://www.adafruit.com/product/1463
Looking to use this for a camera lighting ring, is there anything brighter? If not, I will start experimenting with this one. Thanks!
cwcorbin
Re: Question for NeoPixel Ring
by adafruit_support_carter on Wed Jan 08, 2020 8:25 pm
One of the RGBW rings might be a little brighter:
https://www.adafruit.com/category/184
since it has an additional LED for the white (W) channel. Checkout these projects which use NeoPixels for camera lighting:
https://learn.adafruit.com/3d-printed-camera-led-ring
https://learn.adafruit.com/camera-ring- ... t/overview
Keep in mind that you will need to also have a microcontroller running code to drive the NeoPixels.
There is also this:
https://www.adafruit.com/product/4433
which is a simple LED and just needs power.
by cwcorbin on Wed Jan 08, 2020 9:43 pm
Perfect! As long as they are the same control signals as the RGB? The website for the controller I am using ( Drone Flight Controller ) references your WS2812 document. Does the RGBW use a different spec? Thanks
cwcorbin
by adafruit_support_carter on Wed Jan 08, 2020 10:04 pm
The RGB and RGBW use the same basic signal, but the RGBW's expect extra data for each pixel for the W. So you can't just plug RGBW's into something designed for RGB's and expect them to work. Your Drone Flight Controller would need to have support for RGBW's.
