Neopixel 30 RGBW LED Strip not Lighting Up
by jazzman1967 on Sun Jan 12, 2020 12:09 am
I bought the Neopixel RGBW strip with 30 LEDs per meter. (Product ID 2835). I am having difficulty getting it to light up. I didn't have a 1,000 µF capacitor. So I put 5 220 µF capacitors in Parallel. This brought me up to 1,100 µF. I started out with a 220 Ω & a 330 Ω resistor (a total of 550 Ω) on the data line. I initially had a 2 meter strip and checked the end connection, but I was only getting 2V to 3V. I only had a 2A 5 volt power adaptor. So I thought maybe I was trying to drive too many LEDs. I cut the strip to only have 30 LEDs. Now I get ~5 volts at the end. But all that ever happens is the first LEDs lights up a faint blue. Nothing else lights up. I don't see any issues in the circuit and I even tried just a basic test program:
#define PIN 6
#define N_LEDS 30
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_GRBW + NEO_KHZ800);
// put your setup code here, to run once:
strip.begin();
// put your main code here, to run repeatedly:
chase(strip.Color(255,0,0));
chase(strip.Color(0,255,0));
chase(strip.Color(0,0,255));
static void chase(uint32_t c) {
for(uint16_t i = 0;i<strip.numPixels()+4;i++) {
strip.setPixelColor(i,c);
strip.setPixelColor(i-4,c);
strip.show();
delay(1000);
Still nothing.
Any ideas where I have gone wrong here?
Neopixel soldering
Neopixel Connection Reduced.jpg (890.29 KiB) Viewed 32 times
Breadboard connections
Breadboard Reduced.jpg (826.72 KiB) Viewed 32 times
Arduino Pin Connection GND and PWM 6
Arduino Connection Reduced.jpg (848.7 KiB) Viewed 32 times
jazzman1967
Re: Neopixel 30 RGBW LED Strip not Lighting Up
by kcl1s on Sun Jan 12, 2020 7:49 am
What pin does the red wire in your photo go to on the Uno? Make sure you have a common ground between the Uno and supply if you are using a separate power supply. Can you show the power supply connections too?
Fellow hobbyist
Keith
kcl1s
by adafruit_support_bill on Sun Jan 12, 2020 8:42 am
Connect the data line directly from the Arduino to the pixels. A termination resistor is only needed for longer runs. And the resistors on your photo are not serving any purpose at all in that position. In order to act as a termination resistor, the resistor needs to be connected at the end of the wire closest to the pixels as described here: https://learn.adafruit.com/adafruit-neo ... -practices
