NeoPixel Digital RGB LED Strip something wrong
by KASEKI on Sun Jan 12, 2020 10:59 pm
Hello, I did receive NeoPixe Digital RGB LED Stripb (invoice No.2223406, MNP:2540 white 60 LED 2m).
Then I did pre-check NeoPixe, only 8 LEDs are flashing.
Other LEDs not ON.
I checked input volte which is 5.3V DC.
Configuration is followed.
https://learn.adafruit.com/firewalker-l ... it-diagram
Photo is attachment file.
Sketch is followed.
const int analogInPin = A9;  // Analog input pin that the potentiometer is attached to
Adafruit_NeoPixel strip = Adafruit_NeoPixel(10, 6, NEO_GRB + NEO_KHZ800);
int sensorValue = 0;        // value read from the pot
  // initialize serial communications at 9600 bps:
  Serial.begin(9600);
 pinMode(9, INPUT_PULLUP);
   strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.println(sensorValue);
if (sensorValue < 100){
  Serial.println("leds triggered");
colorWipe(strip.Color(255, 0, 0), 25);
colorWipe(strip.Color(0, 0, 0), 25);
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
スクリーンショット 2020-01-13 11.50.06.png (885.88 KiB) Viewed 56 times
KASEKI
Re: NeoPixel Digital RGB LED Strip something wrong
by dastels on Mon Jan 13, 2020 12:59 pm
There are several potential/likely problems:
1. You're initializing the strip to use 10 neopixels.
Change the first argument of:
to be how many pixels are in your strip, which sounds like 120 (2m of 60 pixel/meter strip).
2. With that many pixels, you will run into power issues.
This could also be a problem you are seeing (especially if it is 8 of the specified 10 pixels that are lighting. You'll need an external power supply. 5v 4A is probably adequate unless you plan to have all the pixels bright and/or white. In that case you'll need a 5v at 6 or 7 A supply.
3. The Data signal for NeoPixels needs to be close to their power voltage.
So if you have 3.3v logic as the Flora does, you should be powering the pixels with 3.3v (or slightly over). If you power the strip with 5v, you'll need a level shifter https://www.adafruit.com/product/1787 to convert the 3.3v signal to a 5v signal. See https://learn.adafruit.com/neopixel-levelshifter
That's a lot of info, but NeoPixels can be picky.
For all things NeoPixel, please see https://learn.adafruit.com/adafruit-neopixel-uberguide
dastels
by KASEKI on Sat Jan 18, 2020 8:51 pm
Dear dastels,
Thank you for your advice.
As your following advice, this problem is solved.
(I change parameter 10 to 20).
CODE: SELECT ALL | TOGGLE FULL SIZE
KASEKI
by dastels on Sat Jan 18, 2020 9:44 pm
Excellent!
dastels
