Eink text misaligned
by papakujawa on Mon Jan 13, 2020 2:58 am
2.13 inch feather E-ink test displays text diagonally instead of horizontally. The example sketch: Adafruit EDP -> test_text displays text as expected. When the "large block of text" is split into two display.print's the display no longer displays as expected. Please explain what causes this effect and the proper way to display multiple lines.
[code display.setRotation(2);
// large block of text
display.clearBuffer();
display.setTextWrap(true);
display.setCursor(10, 10);
display.setTextSize(1);
display.setTextColor(EPD_BLACK);
display.print("Get as much education as you can. "); // <-- split line here
display.print("Nobody can take that away from you"); // <-- now second line
display.setCursor(50, 70);
display.setTextColor(EPD_RED);
display.print("--Eben Upton");
display.display();][/code]
[img]
[/img]
Eink 2-13 feathwing.jpg (903.5 KiB) Viewed 35 times
papakujawa
Re: Eink text misaligned
by papakujawa on Mon Jan 13, 2020 10:50 pm
Configuration:
2.13 Eink feather connected to WINC1500 running on Metro Express.
Pins:
int cs = 10; // CS pin
int irq = 7; // Irq pin
int rst = 5; // Reset pin
int en = -1; // Enable pin
#define EPD_CS      6
#define EPD_DC      8
#define SRAM_CS     3
#define EPD_RESET   2 // can set to -1 and share with microcontroller Reset!
#define EPD_BUSY    -1 // can set to -1 to not use a pin (will wait a fixed delay)
Tried putting the Eink feather on an UNO and it appears to work but no text is displayed.
Will this feather not work on an UNO?
papakujawa
