2.2" 18-bit color TFT LCD and Teensy: white screen only
by phliar on Tue Jan 14, 2020 3:49 pm
Hi, I just got the 320x240 color TFT screen, and I'm trying to use it with a Teensy 4.0.
The TFT breakout is configured for SPI, and I'm using hardware SPI. I've doubled-checked all SPI connections with a multimeter. All the connections on the breakout are connected to the Teensy: based on previous messages here about the display, I bring the RESET line low, wait 1ms, then high.
The screen stays white. All the debugging values from "graphicstest" are 0x0. Prior messages in this forum point to a possible SPI wiring issue; but I've checked them all with a multimeter.
I've tried both the "Adafruit_ILI9341" lib and Paul Stoffregen's "ILI9341_t3" lib; same results on both, i.e. the screen stays white.
My sketch is a simple test program: bring RESET up, call begin(), fill the screen with black, draw one rectangle, one line, and text. I can post the code if required.
phliar
Re: 2.2" 18-bit color TFT LCD and Teensy: white screen only
by phliar on Tue Jan 14, 2020 4:33 pm
I thought I might as well post the code, please delete this message if it's not required....
// Use https://github.com/PaulStoffregen/ILI9341_t3 instead?
#define USE_T3
#include <SPI.h>
#include <Wire.h>
#ifdef USE_T3
#include <ILI9341_t3.h>
#else
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#endif
const int tftWidth = 320;
const int tftHeight = 240;
const int tftDC = 4;
const int tftCS = 10;
const int tftSDCS = 5;
const int tftReset = 6;
// HW SPI on the Teensy 4.0:
// SCLK = 13
// MISO = 12
// MOSI = 11
// The backlight pin on the TFT
const int8_t tftBacklight = 15;
// The TFT panel, using HW SPI.
#ifdef USE_T3
ILI9341_t3 tft = ILI9341_t3(tftCS, tftDC);
#else
Adafruit_ILI9341 tft = Adafruit_ILI9341(tftCS, tftDC);
#endif
const int tftFG = ILI9341_ORANGE;
const int tftBG = ILI9341_WHITE;
const int tftTXT = ILI9341_DARKGREEN;
    digitalWrite(tftReset, LOW);
    delay(1);
    digitalWrite(tftReset, HIGH);
    digitalWrite(tftBacklight, HIGH);
    tft.begin();
    tft.fillScreen(ILI9341_BLACK);
    Serial.begin(115200);
    while (!Serial)
    Serial.println("Started.");
    // read diagnostics (optional but can help debug problems)
    uint8_t x = tft.readcommand8(ILI9341_RDMODE);
    Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
    x = tft.readcommand8(ILI9341_RDMADCTL);
    Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
    x = tft.readcommand8(ILI9341_RDPIXFMT);
    Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
    x = tft.readcommand8(ILI9341_RDIMGFMT);
    Serial.print("Image Format: 0x"); Serial.println(x, HEX);
    x = tft.readcommand8(ILI9341_RDSELFDIAG);
    Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
    tft.setTextColor(tftTXT);
    tft.setTextWrap(false);
    tft.fillRect(5, 5, 100, 100, tftBG);
    tft.drawRect(5, 5, 100, 100, tftFG);
    tft.drawLine(5, 5, 100, 100, tftFG);
    tft.setCursor(6, 90);
    tft.print("Hello, world!");
void loop() {}
phliar
by adafruit_support_mike on Wed Jan 15, 2020 5:37 am
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
by phliar on Wed Jan 15, 2020 12:08 pm
Thanks, here it is. The display goes into row G of the breadboard. (The wires go under the TFT breakout, so I popped it off to make the connections visible. Ignore the button and potentiometer, not used by the test sketch.)
phliar
by paulstoffregen on Sun Jan 19, 2020 6:15 am
I have a test board here with that display (perhaps an earlier version?) that was meant to use Teensy 3.2.
Since Teensy 4.0 has SPI pins in the same locations, I put a Teensy 4.0 on it and run the ILI9341_t3 graphicstest example, to check if ILI9341_t3 running on Teensy 4.0 really work with this display.
Yup, works fine. Here's a photo:
Last edited by paulstoffregen on Sun Jan 19, 2020 6:20 am, edited 1 time in total.
paulstoffregen
by paulstoffregen on Sun Jan 19, 2020 6:16 am
Here's a photo of the wiring on the bottom side of that board.
paulstoffregen
by adafruit_support_mike on Sat Jan 25, 2020 1:53 am
Sorry for the delay.
The connections above look okay. Can you get the display to work with any other kind of microcontroller?
