ILI9341 sketch generates compile errors
by efmisoyannis on Sat Feb 01, 2020 9:44 am
We purchased a 2.8" capacitive touchscreen display, fired it up and ran the test code as per the website no issues. We now want to build BMP images and display them. To do so we ran the ShieldILI9341 sketch but it gives us a lot of compile errors related to the SPI. It seems the SPI registers on the AVR are being accessed from multiple functions but the SFR registers are not visible to those functions. The board is an Arduino Uno WiFi Rev 2. Below is the error dump with most of it removed (it gets repetitive). The start and end are included.
The link we followed is below
https://learn.adafruit.com/adafruit-2-8 ... ng-bitmaps
There seemed to be an alternative link as well that suggested the SdFat library be installed manually but it made no difference (we tried it in hope).
https://learn.adafruit.com/adafruit-gfx ... ing-images
Tried changing the board type to a UNO but different errors came up. Also tried changing register Emulation to ATMEGA328 and None (AVR4809) and neither worked. We're using none for our board.
Arduino IDE version is 1.8.10
Any suggestions are welcome.
Ef
Arduino: 1.8.10 (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
In file included from C:\Users\ef\Documents\Arduino\libraries\SdFat\src/SdCard/SdSpiCard.h:35:0,
from C:\Users\ef\Documents\Arduino\libraries\SdFat\src/BlockDriver.h:32,
from C:\Users\ef\Documents\Arduino\libraries\SdFat\src/SdFat.h:32,
from C:\Users\ef\Documents\Arduino\libraries\Adafruit_ImageReader_Library\examples\ShieldILI9341\ShieldILI9341.ino:12:
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h: In member function 'uint8_t SdSpiAltDriver::receive()':
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h:392:3: error: 'SPDR' was not declared in this scope
SPDR = 0XFF;
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h:392:3: note: suggested alternative: 'SPI'
SPDR = 0XFF;
SPI
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h:393:12: error: 'SPSR' was not declared in this scope
while (!(SPSR & (1 << SPIF))) {}
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h:393:12: note: suggested alternative: 'SPI'
SPI
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h:393:25: error: 'SPIF' was not declared in this scope
c:\users\ef\documents\arduino\libraries\sdfat\src\spidriver\sdspidriver.h:393:25: note: suggested alternative: 'SPI'
Multiple libraries were found for "Adafruit_GFX.h"
Used: C:\Users\ef\Documents\Arduino\libraries\Adafruit_GFX_Library
Multiple libraries were found for "Adafruit_ILI9341.h"
Used: C:\Users\ef\Documents\Arduino\libraries\Adafruit_ILI9341
Multiple libraries were found for "SPI.h"
Used: C:\Users\ef\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.5\libraries\SPI
Multiple libraries were found for "SdFat.h"
Used: C:\Users\ef\Documents\Arduino\libraries\SdFat
Multiple libraries were found for "Adafruit_SPIFlash.h"
Used: C:\Users\ef\Documents\Arduino\libraries\Adafruit_SPIFlash
Multiple libraries were found for "Adafruit_ImageReader.h"
Used: C:\Users\ef\Documents\Arduino\libraries\Adafruit_ImageReader_Library
Multiple libraries were found for "Adafruit_EPD.h"
Used: C:\Users\ef\Documents\Arduino\libraries\Adafruit_EPD
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
ShieldILI9341.ino
Shield code that won't compile
(5.91 KiB) Downloaded 6 times
efmisoyannis
Re: ILI9341 sketch generates compile errors
by franklin97355 on Sat Feb 01, 2020 10:34 am
Do you have the ZeroDMA library installed?
franklin97355
by efmisoyannis on Sat Feb 01, 2020 4:13 pm
Hi, No I didn't so I installed it but it made no difference unfortunately. Thanks for responding. Much appreciated.
All ideas welcome
efmisoyannis
by thorx on Thu Feb 20, 2020 5:02 pm
I was just having the same problem: ILI9341 based TFT on top of an Arduino UNO Wifi Rev 2, and the SDFAT driver refuses to compile. Same errors.
The reason for these compilation errors is in the microcontroller: while the common UNO uses an ATmega328P, the Wifi Rev 2 uses a ATmega4809 which is quite a different chip. The SPI registers are different, so any code referring directly to ATmega328P SPI registers won't compile for ATmega4809. I did some googling, saw that more people have encountered the problem, but I couldn't find a quick solution.
I went over the ATmega4809 data sheets and made some changes to the code myself that should solve compilation errors for the ATmega4809. In the file SdSpiDriver.h, go to the lines below (line 372 in my version of the file)
// Use of in-line for AVR to save flash.
#ifdef __AVR__
and change this to
#ifdef __AVR__
#if defined (__AVR_ATmega4809__)
#define SPDR SPI0_DATA
#define SPSR SPI0_INTFLAGS
#define SPIF 7
#endif // __AVR_ATmega4809__
This basically replaces the ATmega328P register references with ones for the ATmega4809. I hope this helps you.
Caveat: I'm not an expert of any kind on this low-level microcontroller stuff. This code fix likely works, but there is a chance it is not the fastest possible code for the ATmega4809. However, with the ILI9341 example sketch I do not notice a speed difference between my UNO R3 and my UNO Wifi Rev2, so I am hopeful it is a good fix.
thorx
by efmisoyannis on Sun Mar 01, 2020 6:07 am
Hi Thorx,
sorry I didn't see this until now. Thanks for doing all this work. We'll try it out.
Regards
Ef
efmisoyannis
by cdno on Sat May 08, 2021 12:56 am
I had the same problem now with this example using the adafruit 128x96 oled and an arduino nano every (mega4809)
The example I was following was this https://learn.adafruit.com/adafruit-1-5 ... ng-bitmaps
The changes suggested by thorx above worked nicely! Thanks!
cdno
