Clean exit from pygame on PiTFT
by bobthechemist on Sat Feb 29, 2020 4:36 pm
I have an old RPi B with a 3.5" PiTFT display on it. The RPi is running the most recent version (as of 2/29/2020) of Raspian lite and I followed https://learn.adafruit.com/adafruit-amg8833-8x8-thermal-camera-sensor/raspberry-pi-thermal-camera to set up thermal imaging.
First, I believe that page needs to be updated to download the python3 versions of scipy and pygame
sudo apt-get install -y python3-scipy python3-pygame
Next, the instructions run very smoothly, but when I try to exit the rpi_thermal_cam.py code with a keyboard interrupt, it does not actually stop. If I SSH into the RPi and kill the process, the screen stops updated but does not return to the console.
If I run rpi_thermal_camp.py from ssh (with a client such as MobaXTerm with tunneling) then I get a screen on my computer with the thermal image, but the PiTFT does not update. I thought setting the environment such as found here https://raspberrypi.stackexchange.com/questions/12448/pygame-from-console-with-pitft would fix that issue but it does not.
Q1. How do I cleanly exit a python program that uses pygame to display on the PiTFT so that the console is returned upon program completion?
Q2. How do I force a python program to display (via pygame) on the PiTFT regardless of being called from the console or via SSH?
bobthechemist
Re: Clean exit from pygame on PiTFT
by IOTothemax on Sat Feb 29, 2020 4:38 pm
Could you please post your code? That way, we can see what's missing and what might be a bug.
IOTothemax
by bobthechemist on Sat Feb 29, 2020 4:46 pm
It is the code directly from Adafruit's website here https://learn.adafruit.com/adafruit-amg8833-8x8-thermal-camera-sensor/raspberry-pi-thermal-camera. It runs as expected; I just cannot exit the program with a keyboard interrupt (CTRL-C) from an attached USB keyboard.
bobthechemist
by tonyromano51 on Fri Sep 11, 2020 12:52 am
Mine would not exit from piTFT display either, so I modified the code to add "from gpiozero import Button" , and "button17 = Button(17, hold_time=3)" , near the top, and at the bottom I added "if button17.is_held:" newline, indent "exit()" . If gpiozero is not found load it with $pip3 install gpiozero . [button 17 is the lower left (landscape) button on the PiTFT 2.8"]
Even though this post is old, I hope this helps anyone else trying it.
tonyromano51
