After the easy install, my touch screen is not responsive. The screen displays, but the touch function does not work. I ran the manual install and I get
"E: Unable to locate package tslib"
When trying to install the evtest tslib. Where can I find this or fix the issue?
Thx!
PID: 1601 2.8 pitft Touch Lib not found
- rob drizzle
Re: PID: 1601 2.8 pitft Touch Lib not found
No one else has had this issue??
- adafruit_support_carter
What if you try the Easy Install process?
https://learn.adafruit.com/adafruit-pit ... -install-2
- rob drizzle
Yes, the results described above were after the Easy Install Script.
Can you please clarify if you ran the Easy Install:I ran the manual install and I get
or the manual install:
https://learn.adafruit.com/adafruit-pit ... -calibrate
- rob drizzle
Both. The easy first and noticed that the events wasn't working to calibrate and tried to manually get using the apt-get and the package wasn't found.
Specifically what events? What OS version are you running?
- rob drizzle
Sorry, that was an autocorrect. EventX not events.
Its the latest version of OctoPI 0.17.0
For the sake of troubleshooting, can you please try with the version of Raspbian mentioned as last-known tested and run the Easy Install script again with that:
https://learn.adafruit.com/adafruit-pit ... d-card-3-4
For now, don't go into any of the manual setup steps. Just Raspbian + Easy Install Script and let's see what happens.
- rob drizzle
Ok. I will give it a try.
