So I recently purchased a Adafruit RA8875 Driver Board with the recommended 5" TFT 40pin LCD with Resistive Touch, 800x400. I will be driving using my teensy 4.0.
I am planning on using this for my E-Bike control screen and interface the teensy with my BMS as well as the ebike controller to control pedal assist, motor power and display speed and other information.
It didn't occur to me at the time when I ordered but I am going to need a brighter display as the datasheet says the panel is 200 nits brightness which I will struggle to see in direct sunlight when out on the road.
Can anyone recommend or know of what type of panels this driver can work with. Am I right in saying that as long as it uses the 40pin interface I can use any panel? Ideally a panel that can put out 700+ nits would be great.
