Pi TFT and Python 3
Pi TFT and Python 3
by tarnis on Sat Aug 01, 2020 5:59 pm
I see most of the examples used 2.7, and some code I've written does work in 2.7 but I started out trying to write a script in 3.0 to control the buttons on the screen as well as some extra buttons I'm wiring into the GPIO pins through a ribbon cable connected to the output that's soldered onto the board. Python gives errors and seems to think that I do not have a raspberry pi if I do any of that in 3.0 though.
Is there a workaround? 2.7 is a little old at this point and going away fairly soon.
tarnis
Re: Pi TFT and Python 3
by tarnis on Sat Aug 01, 2020 7:48 pm
Python 2
pi@PiCam:~/scripts $ sudo python2
Python 2.7.16 (default, Oct 10 2019, 22:02:15)
[GCC 8.3.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import RPi.GPIO as GPIO
>>> quit()
Python 3
pi@PiCam:~/scripts $ sudo python3
Python 3.7.3 (default, Dec 20 2019, 18:57:59)
  File "<stdin>", line 1, in <module>
RuntimeError: This module can only be run on a Raspberry Pi!
tarnis
by adafruit_support_carter on Mon Aug 03, 2020 12:30 pm
What TFT and guide are you working with? In general, anything new will be Python 3. Anything you might come across that is Python 2 is outdated and we should update it.
by tarnis on Mon Aug 03, 2020 12:56 pm
It's the PiTFT Plus 320x240 3.2" TFT + Resistive Touchscreen
I used these directions a few months back when I bought it, finally finding some time to begin writing some code and finding nothing works in python 3.
https://learn.adafruit.com/adafruit-pit ... spberry-pi
Regards,
Matt
tarnis
by tarnis on Mon Aug 03, 2020 9:33 pm
I think I have things sorted out, but I'm not sure where things went off the rails...I assumed the installer script maybe installed an old copy of RPi.GPIO but I don't see it in there...nor OpenCV which is the only other thing I installed and yet it's here. I deleted the directory from python and I think that cleared things up so its using the default raspian install now.
tarnis
