7 segment 1.2" LED Brightness
Re: 7 segment 1.2" LED Brightness
by XRAD on Thu Aug 20, 2020 7:59 pm
These segments are much brighter than you show when working. But, it could be the voltage regulator on the metro. Do you have a volt meter to test the 5v pin?
XRAD
by adafruit_support_carter on Fri Aug 21, 2020 12:33 pm
The fact that you are seeing a change in apparent brightness depending on the number of segments being lit does seem to indicate some kind of power issue. Other things to check are the wires being used and the soldering on the header pins. And soldering in general, so check the matrix pins as well.
by bmwflyboy on Sat Aug 22, 2020 10:53 am
I put a meter to the 5v line coming out of the metro. On a 9v power supply it was showing 4.98v. I plugged the board into a wall wart 5v @ 2A power supply and the meter showed 4.88v. I think the soldering looks good. I attached photos in case better trained eyes might see something I am not.
bmwflyboy
by bmwflyboy on Sat Aug 22, 2020 10:54 am
Additional photos.
bmwflyboy
by adafruit_support_carter on Mon Aug 24, 2020 12:01 pm
Thanks for the photos. That power supply should be more than adequate. There are a few pins that look possibly cold soldered and not wetted out enough on the pads. See here:
https://learn.adafruit.com/adafruit-gui ... n-problems
Check all the pins and try reflowing any that may need it with your soldering iron.
by bmwflyboy on Mon Aug 24, 2020 1:29 pm
I will check/re-do some and report back at some point. Thank you.
bmwflyboy
by bmwflyboy on Fri Aug 28, 2020 10:53 am
I was redoing the soldering and stupidly wiped the contacts with a moist rag while it was powered up. It shorted the board out. I ordered a new one. We'll see how that goes.
bmwflyboy
