32x64 RGB Matrix with Metro M4 Airlift Lite Behaving Badly
by rwbrenton on Thu Aug 20, 2020 7:03 pm
Okay, so I carefully followed this because I'm a massive newb at this stuff: https://learn.adafruit.com/32x16-32x32-rgb-led-matrix/overview
I'm going through it with a Metro M4 Airlift Lite and the 5V 4A (4000mA) switching power supply - UL Listed.
I cut the PCB trace between the two pads next to the clk and soldered a wire from the adjacent “CLK” pin to the “Analog In 4” pin as directed. I also updated the code to use A4 for the clock.
What I've ended up with looks like it's trying real hard, but sadly failing.
https://www.youtube.com/watch?v=WiksY9hq_Gk
Pictures of the connections are attached.
rwbrenton
Re: 32x64 RGB Matrix with Metro M4 Airlift Lite Behaving Bad
by adafruit_support_carter on Fri Aug 21, 2020 3:30 pm
Which example sketch are you running?
by rwbrenton on Fri Aug 21, 2020 3:34 pm
testshapes_32x64
rwbrenton
by adafruit_support_carter on Fri Aug 21, 2020 3:36 pm
Thanks. Sorry, should have also asked, which specific matrix display. You can just link to product page.
by rwbrenton on Fri Aug 21, 2020 3:40 pm
rwbrenton
by adafruit_support_carter on Fri Aug 21, 2020 4:03 pm
OK, one quick thing to check - are you on the correct connector on the back of the matrix panel? See here for how to check:
https://learn.adafruit.com/32x16-32x32- ... new-wiring
by rwbrenton on Fri Aug 21, 2020 4:12 pm
Sorry, I thought I had included this picture. I connected it to the DATA_IN.
rwbrenton
by adafruit_support_carter on Fri Aug 21, 2020 4:21 pm
Thanks. That looks correct.
Did you do a continuity check on the scratched pad to make sure it actually go disconnected?
Is the Airlift the only Metro board you have?
by rwbrenton on Fri Aug 21, 2020 4:30 pm
I have not. I will try that and get back to you.
rwbrenton
by adafruit_support_carter on Fri Aug 21, 2020 4:33 pm
Thanks. Also, can you post another photo of the shield that's more from this angle:
https://learn.adafruit.com/assets/55701
That will help us better check the soldering on the header pins.
by rwbrenton on Fri Aug 21, 2020 6:01 pm
I did a continuity check and that scratched pad is definitely disconnected. Here are a couple more shots of the shield.
Shield Close 1.jpg (1002.42 KiB) Viewed 16 times
Shield Close 2 small.jpg (528.73 KiB) Viewed 16 times
rwbrenton
by adafruit_support_carter on Mon Aug 24, 2020 11:44 am
Thanks for the photo. I'd suggest going over all your pins and checking the soldering. Some look OK, but others look like they may be potentially cold soldered and not wetted out enough on the pads. The SCL pin in particular is definitely not wetted out enough. But that pin is not used for the RGB matrix, so that's not the specific issue here. But could be a similar pin(s) somewhere else.
Similarly for all the pins underneath on the ribbon cable connector.
Good info here:
https://learn.adafruit.com/adafruit-gui ... n-problems
For any pins that look like they need re-work, you can just go back in with your soldering iron and try reflowing them.
by rwbrenton on Mon Aug 24, 2020 5:59 pm
So I went through and tried to correct anything that didn't look like it was soldered correctly. This is where we are now, with the same results:
rwbrenton
by adafruit2 on Tue Aug 25, 2020 12:02 pm
can you post a screenshot of your arduino ide Tools menu? like what you have selected?
adafruit2
Site Admin
by rwbrenton on Tue Aug 25, 2020 12:10 pm
rwbrenton
