Oddity of OLEDDisplay.setColor(...)
by droidxn on Fri Aug 21, 2020 9:39 am
My first post here!
I am somewhat new to c/cpp and that could be the primary reason to this post.
This part of the code snippet works:
SH1106Wire display(oledAddress, SDA, SCL);
// line is => struct line {float stX, float stY, float spX, float spY}
void eraseLine(line l)
    // This draws a black line resulting in erasing
    display.setColor(BLACK);
    display.drawLine(l.stX, l.stY, l.spX, l.spY);
    display.setColor(WHITE);
Now, I tried to move the code to a separate .cpp and .h file (BTW, I am using PlatformIO). So, I am passing the instance of the display (SH1106Wire) as a pointer.
Could this (passing pointer) be an issue?
SH1106Wire display = SH1106Wire(oledAddress, SDA, SCL);
MyLib lib = MyLib();
lib.init(&display); // <- Is there a better way to pass the display. Note: Type here is SH1106Wire
// -- Code below are in MyClass.cpp
void MyLib::init(OLEDisplay *display){  // <- Could this be the problem. Note: Type here is OLEDdisplay
   _display = display;
    _display->setColor(BLACK);
    _display->drawLine(l.stX, l.stY, l.spX, l.spY);
    _display->setColor(WHITE);
I am baffled why the 1st piece of code works whereas the second piece (where I moved things to a lib doesn't. Drawing a WHITE (blue in my case) works fine in the lib but not erasing. Any suggestions?
droidxn
