PiOLED display issues
by dky on Sat Aug 29, 2020 2:13 pm
Renders a single line when pressed.
Hello, I'm writing because I'm currently having an issue with the PiOLED product.
After getting the drivers installed according to:
https://learn.adafruit.com/adafruit-pio ... pberry-pi/
When I attempt to render the stats.py info:
https://github.com/adafruit/Adafruit_Ci ... 6_stats.py
I can't get the full display to render. However, I started wiggling the connector I would notice a few lines flicker on and off. I pressed the display lightly and more lines render. It appears to be an issue with the ribbon from what I can tell...
Any ideas? Attached are some photos of what renders.
dky
Re: PiOLED display issues
by dky on Sat Aug 29, 2020 2:14 pm
The pictures display a few lines rendering when I lightly press on the ribbon cable. However I've never gotten the full display to render.
dky
by adafruit_support_carter on Mon Aug 31, 2020 2:42 pm
Weird. Can you post a photo of the backside of the OLED so we can look for anything obvious with the hardware. A photo similar to this:
https://cdn-shop.adafruit.com/970x728/3527-00.jpg
by dky on Mon Aug 31, 2020 10:18 pm
Sure! Here you go, super close ups of back + front.
dky
by adafruit_support_carter on Mon Aug 31, 2020 10:29 pm
Thanks. The solder side looks OK. Maybe some damage to the upper part of the ribbon cable? But not sure. Is this a new OLED, or has it been in use?
by dky on Mon Aug 31, 2020 10:49 pm
Hello, its new from order:
Re: Order Confirmation No: 2348938-2158413492
I don't have the sticky tape over the led though, I removed that and it somehow disappeared.
dky
by adafruit_support_carter on Tue Sep 01, 2020 11:37 am
OK. Not sure what's happening. But seems like some kind of marginal connection issue. Let's just replace it.
Send an email to support@adafruit.com with a link to this thread (order number is above) and they can send you a replacement PiOLED.
