Loading image 'woof.bmp' File not found
by Diazita on Mon Aug 31, 2020 12:17 pm
i have a Adafruit 3.5" 320x480 Color TFT Touchscreen Breakout, try with tftbmp_shield but my serial say:
Unknown LCD driver chip: F9F9
If using the Adafruit 2.8" TFT Arduino shield, the line:
#define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
Loading image 'miniwoof.bmp'
File not found
Diazita
Re: Loading image 'woof.bmp' File not found
by Diazita on Mon Aug 31, 2020 1:35 pm
with tftbmp, it say :
Found HX8357D LCD driver
Initializing SD card...failed!
File not found
Diazita
by Diazita on Mon Aug 31, 2020 6:58 pm
i try with spi setup and spitftbitmap, it say :
Initializing SD card...OK!
Loading image '----.bmp'
File size: 8420
Image Offset: 54
Header size: 40
Bit Depth: 24
Image size: 67x41
Loaded in 1522 ms
but i don t see any picture
Diazita
by mikeysklar on Mon Aug 31, 2020 8:11 pm
Hi Diazita,
The first issue with USE_ADAFRUIT_SHIElD_PINOUT showing up. This line needs to be commented out of the Adafruit_TFTLCD.h as the guide suggests.
// #define USE_ADAFRUIT_SHIELD_PINOUT
Make sure this line is commented out with a // in front (it should but if you're having issues, its worth checking.
https://learn.adafruit.com/adafruit-3-5 ... g-and-test
Your next issue with the SD Card not initializing. This could be wiring, but it is also not finding the BMP file. Take a look at these two guides and let me know if the wiring is in place and the example files are on the card. Please start with our example images to remove some unknowns.
https://learn.adafruit.com/adafruit-3-5 ... s-spi-mode
https://learn.adafruit.com/adafruit-gfx ... ing-images
mikeysklar
