Feather + HX8357 TFT 8 bit parallel mode
by hypercubed on Fri Sep 04, 2020 1:28 pm
I recently acquired the 3.5 inch touchscreen (2050) and it works great.
However, I do find that SPI mode is very slow at redrawing the screen (I find over a second per refresh)
The reason I would need more speed is because I have text input with vertical scroll as well as whole-screen pictures. When I'm inputting and the screen is not full it works fine because I can just update that character.
But when the screen is full and I enter a newline the whole screen has to refresh because all the text has to get bumped up one line.
I tried turning on DMA ( by editing Adafruit_SPITFT.h and uncommenting the
#define USE_SPI_DMA
line) but it's still slow.
So I thought the best way to increase the speed would be to use 8-bit parallel mode instead of SPI. I don't mind using all those extra pins because I only need one other one for this project.
I saw this video https://www.youtube.com/watch?v=ClabKcWVxT8 and the description says it uses ATSAMD51 which is what my Feather uses. Would it be possible to get the source code/library for that?
The Adafruit Learn article for my screen (https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout/8-bit-wiring-and-test) has a tutorial for connecting via 8-bit parallel but it only shows the Arduino Uno wiring.
It also says:
The 8-bit mode is hand-tweaked in the Adafruit_TFTLCD pin_magic.h file. Its really only for advanced users who are totally cool with figuring out bitmasks for various ports & pins.
If that's the route I need to go (I'm assuming using the TFTLCD library and editing the pins_magic.h), how would I go about doing it? Or has someone done it already?
hypercubed
Re: Feather + HX8357 TFT 8 bit parallel mode
by mikeysklar on Tue Sep 08, 2020 4:43 pm
Hello hypercubed,
You are on the right track with 8 bit parallel DMA being must faster than SPI.
We have the Amiga bouncing ball graphic demo buried in one of our PyPortal guides and on github:
Amiga Boing!
As featured above, this draws a checkered ball around the screen, a classic Amiga demo. Available in the Adafruit_ILI9341 library as the pyportal_boing demo. It's an intense demo showing how to calculate a scan line and render it post computation.
https://learn.adafruit.com/adafruit-pyp ... hics-demos
https://github.com/adafruit/Adafruit_IL ... rtal_boing
Also some M0/M4 performance options:
https://learn.adafruit.com/adafruit-pyp ... ches-to-m0
mikeysklar
