My Star Trek Day project needs help! Dimming flex strip?
by neoBigD on Tue Sep 08, 2020 4:49 pm
Happy Star Trek Day everyone! I realized i had been putting off a project i started while back using that great flex led strip stuff. But after assembling my design (the great Delta symbol!) i noticed its quite bright! I'm looking for a simple method to create a dimmer control for this but i doubt just putting a rheostat in-line on the 12v line is good, let alone safe.
Any suggestions that i can create today with simple components most people would have around? (i have quite a few parts)
Thanks all, and Live Long and Prosper!
Update: And yes i have been searching for a solution but find things from complex multi-component ones to simpler ones but using stuff i dont have. I did find these ones that i might try, any input or pros/cons on their setup?
http://www.circuitdiagram.org/simple-12 ... immer.html
http://www.circuitdiagram.org/simple-le ... rcuit.html
Delta test(1).jpg (554.57 KiB) Viewed 37 times
neoBigD
Re: My Star Trek Day project needs help! Dimming flex strip?
by dastels on Tue Sep 08, 2020 9:50 pm
You can't really dim LEDs very effectively the way you can dim incandescent bulbs. generally you will need to use a PWM signal to control a power transistor to rapidly turn the LEDs off & on. The higher % of the time they're on, the brighter they will appear. See https://learn.adafruit.com/transistors-101/example-uses.
dastels
by caitlinsdad on Wed Sep 09, 2020 3:56 pm
Would trying to power it with 9v or something lower than 12v work? Will you still be using a variable bench power supply where you can just dial in the output voltage? Good luck.
caitlinsdad
by dastels on Wed Sep 09, 2020 4:04 pm
I think it depends on exactly what LED strip is involved. Can you link us to the product listing?
dastels
by neoBigD on Wed Sep 09, 2020 6:29 pm
https://www.adafruit.com/product/3866
Reading the product listing, it does mention using from 9v to 12v!
I kind of had the same thought this morning and am testing with a 9v power source, and it does look better in person.
Guess I should have came back to this page to review product info, thanks for the thought!
neoBigD
