32 x 32 LED matrix not working
Re: 32 x 32 LED matrix not working
by blnkjns on Sun Oct 04, 2020 2:34 pm
A Leonardo can be 100% pin compatible with the UNO. The only thing that could be a problem here is that SPI or I2C is used, and those default to the hardware pins on the LEO, but they can be mapped to the UNO pins as well. Remember thought that the LEO also needs a bit of the extra 512 bytes for its USB driver.
blnkjns
by pburgess on Sun Oct 04, 2020 5:43 pm
Library is not Leonardo compatible…it relies on whole-PORT writes for speed, and the Leonardo PORT-to-pin mapping doesn’t match the Uno.
pburgess
by veedub88 on Tue Oct 06, 2020 2:13 am
Ok, thanks I will have to buy a mega and try it on that.
veedub88
by adafruit_support_carter on Wed Oct 07, 2020 1:25 pm
In terms of connections - your initial setup is probably fine. The suggestion for trying the other connection was out of concern for there possibly being a GND issue between the power supply and the UNO, causing a signal level issue to the matrix.
by veedub88 on Mon Oct 12, 2020 2:46 pm
Yup, works just fine with a mega.
veedub88
by ModernBarbarian on Sun Oct 18, 2020 4:46 pm
pburgess wrote:Can confirm: the only option that fits on the Arduino Uno anymore is 32x16, single-buffered. Double-buffered at that size, or anything 32x32, no longer fits. This is due to gradual incremental bloat in the Arduino core and/or the RGBmatrixPanel and Adafruit_GFX libraries.
Well this in incredibly disappointing. I recently planned a project after reading the RGB Matrix tutorial on Adafruit as I already had an Arduino Uno. I bought the 32x32 Matrix and a few sensors plus the matrix shield, now it sounds like I can't use them
ModernBarbarian
