Wiring to extended pins PiTFT mounted to Raspberry Pi
by cntrlengr on Tue Oct 06, 2020 4:27 pm
Has anyone had any success wiring to the extension pins under the PiTFT between the LCD and the Raspi? The length of the standard jumpers is too long so I was curious what anyone has done. Thinking of pulling the pins out and just using a small piece of heat shrink at the bottom.
cntrlengr
Re: Wiring to extended pins PiTFT mounted to Raspberry Pi
by mikeysklar on Thu Oct 08, 2020 12:13 pm
Hi cntrlengr,
Would it make sense to use RT ANGLE connector for the extension pins? We sell a breakaway that could be used by the 2x13 in the rear.
https://www.adafruit.com/product/1541
mikeysklar
by cntrlengr on Sun Oct 11, 2020 11:42 am
Thanks for the suggestion I appreciate that! I just took the plastic off of the jumpers and put on some heat-shrink...bent the connectors a little voila! I connected the AMG-8833 thermal sensor and it works great! Now I am just sorting through the code functionality on the Raspberry Pi 3B+. I am having issues with the scipy module in the sample code. I will probably post a question in another forum thread for that.
Thanks again Mike!
cntrlengr
by mikeysklar on Sun Oct 11, 2020 6:15 pm
Well, that is cool that you worked it out. I can't exactly see what you did, but I think I undersand the slight bending of the pin and heat shrink protection. As long as that doesn't stress anything great..
mikeysklar
