Multitrellis issue
Multitrellis issue
by Moris526 on Thu Oct 08, 2020 5:16 pm
Hi.
I made a 32 Neotrellis units board.
If I just load 6 on the Arduino Multitrellis code it works fine. But If a go beyond that I start to get more and more issues like freezing or data errors.
Im new to electronics but I read it could be a Pullup resistors issue?
I attached a video with a rolling sequencer like light that skips steps or changes colour when a button is pressed
1.zip
(971.19 KiB) Not downloaded yet
Moris526
Re: Multitrellis issue
by dastels on Thu Oct 08, 2020 6:05 pm
The first thing I'd to is make sure all the board interconnect solder joints are rock solid.
dastels
by Moris526 on Thu Oct 08, 2020 6:45 pm
Yes. They are solid.
In fact, I can load any 6 units from the 32 in the multitrellis code and they work just fine.
The pullups theory couldnt be right?
Moris526
by dastels on Thu Oct 08, 2020 7:40 pm
Unlikely. They're all there, all the time.
All your address selector jumpers are correct?
You have adequate power to the trellises (trelli?)?
dastels
by Moris526 on Thu Oct 08, 2020 10:49 pm
Someone suggested that I should remove some pullups...
No problem with the jumpers I think.
I supply power with 5v 10 amp transformer (220v here) connected at 6 different points around the edges.
I really want to make this work. Do you know if I can hire someone to help me?
Moris526
by dastels on Fri Oct 09, 2020 12:54 pm
You can post on the jobs board https://www.adafruit.com/jobs. Did you ask on discord.. #help-with-projects? There are no doubt others that have a 32 neotrellis build. I've only done the 4 trellis kit.
dastels
by Moris526 on Fri Oct 09, 2020 3:21 pm
Thanks you for your time.
Moris526
