Characters moving on the screen
by nordpolemil on Sun Oct 11, 2020 3:02 pm
I encountered a strange issue with the Adafruit Monochrome 128x32 OLED Display. Whenever I redraw the display, the offset moves a bit. So when I draw "hello world" the first time it appears on the screen where expected. When I call my draw function again it moves a bit in X and a bit in Y direction. When I call the draw function in a loop then the text wanders over the screen. I want it to stay where it is. Does anyone know why the text is not printed in the same location every time I call the draw function?
Btw. my display is connected to a Teensy LC.
I made an example code to reproduce the problem. I copied it together from the example codes.
Thank you :)
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  Serial.begin(9600);
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
display.setTextSize(1);             // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE);        // Draw white text
  //display.setRotation(2);
  testdrawstyles();
  delay(100);
void testdrawstyles(void) {
  display.clearDisplay();
  display.setCursor(0,0);             // Start at top-left corner
  display.println("Hello, world!");
  display.display();
nordpolemil
