LED strips around corners
by akmartin on Mon Oct 12, 2020 12:14 pm
I want to run an LED strip around a window frame -- how do you recommend handling corners? Do you have a wire connector that allows the strip to be cut and reconnected?
akmartin
Re: LED strips around corners
by adafruit_support_bill on Mon Oct 12, 2020 12:56 pm
We do not have a special connector. But most strips can be cut and connected via wire and solder. Neopixel and DotStar strips can be cut between any pixels. The 12v analog strips can be cut between every third pixel. In either case, there are solder pads at each cut-point.
by akmartin on Mon Oct 12, 2020 2:14 pm
Fantastic! Thanks!
akmartin
