Loading Adafruit_EPD
by lucentinian on Mon Nov 09, 2020 12:20 pm
Hi team!
Do you know how much capacity do I need to load Adafruit_EPD module with CircuitPython for an e-ink related project? Can an ItsyBitsy M0 Express handle that or do I need a bigger one?
Thank you in advance!
lucentinian
Re: Loading Adafruit_EPD
by mikeysklar on Tue Nov 10, 2020 7:54 pm
If you are drawing bitmaps and using CircuitPython we recommend a Feather M4 Express it has double the memory of the Feather M0 Express 512KB vs 256KB.
You may need a board with more memory such as the Feather M4 or Metro M4 to handle the memory requirements of drawing a bitmap.
https://learn.adafruit.com/adafruit-ein ... ng-bitmaps
https://www.adafruit.com/product/3857
mikeysklar
by lucentinian on Tue Nov 10, 2020 9:49 pm
Thank you for your support @mikeysklar! I've got recently an ItsyBitsy M0 Express then I've tried to use the modules for e-ink. When CircuitPython wanted to load adafruit_il0373 module, it ended with MemoryError. However, I've moved to Arduino sketches for development and now I can draw in the e-ink display.
lucentinian
by mikeysklar on Wed Nov 11, 2020 6:47 pm
Good solution moving to Arduino if you do not mind coding in C. I should have mentioned that, but I usually avoid trying to shift people to another programming language from what they requested. I'll make sure to point that out next time. Congrats.
mikeysklar
