DOA LED sidestripe
DOA LED sidestripe
by rwerner on Tue Nov 10, 2020 4:12 pm
Order Confirmation No: 2397481-0340248464
One strip worked the other was dead.
Robert
rwerner
Re: DOA LED sidestripe
by adafruit_support_carter on Tue Nov 10, 2020 7:52 pm
Please post a photo of your setup showing how the strips are being used.
by rwerner on Thu Nov 12, 2020 8:43 pm
Here it is
rwerner
by adafruit_support_carter on Sat Nov 14, 2020 12:48 pm
That could be connection related. Make sure you are on the input side of the strip. Can you use a breadboard or something to help insure better connections?
by rwerner on Sat Nov 14, 2020 1:31 pm
It’s a quality control issue...the LED arrived dead....the other strip works fine...not a newb...just need a way of getting a return.
Robert
rwerner
by adafruit2 on Sat Nov 14, 2020 2:43 pm
it can happen but its incredibly rare that an LED strip is dead
have you checked that you're sending data into the DIN pin, that you have tried a device with 5V output - an Arduino UNO or compatible is ideal
adafruit2
Site Admin
by rwerner on Sat Nov 14, 2020 3:54 pm
Yea I use these neopixel strips all the time (see my buying history). First time with these side stripe ones but it’s identical twin that it came with is already in a sculpture and working fine. The part is defective to the best of my testing and no amount of texting about the part will change this outcome.
rwerner
by adafruit2 on Sat Nov 14, 2020 4:04 pm
ok email support@adafruit.com for a replacement strip
adafruit2
Site Admin
